Old 12-15-2012, 3:32 PM
Default Is it worth paying to get the PSR-800 optimized?
I know the PSR-800 is a pre-programmed digital scanner so is it worth paying money for a store to set it up and optimized for your local area?
Any feed back is appreciated.
Old 12-15-2012, 3:37 PM
rocksteady's Avatar
No. You can do that yourself. I can't believe someone actually wants to sell that idea to a consumer.
Some friends and family are like a slinky, they don't serve much of a purpose, but they sure are fun to watch when you push them down the stairs.
Old 12-15-2012, 3:38 PM
bgav's Avatar
In my opinion, no. It's fairly easy to do with the included software and forces you how to learn how to do it as well as learning the features of your scanner.
Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime.
HP-1|PSR-800|BC780XLT|Pro-92
PlanePlotter Ground Station ya
Old 12-15-2012, 4:38 PM
Depends on how much money you have. Personally paying someone to open my car door for me is a more useful use of money. I've never done that though.
Serious answer - NO.
Old 12-15-2012, 4:52 PM
pdfdems286's Avatar
you are the one that should know what you want in your scanner. i've never been a proponent of even having my scanners programed by software. like someone else said, it forces you to learn how to program by yourself. you cannot be out in the field and say "hey scannermaster, how do i throw these frequencies into my scanner ?". be as self sufficient as possible. the other part is, i hate paying somebody to do what i can do.
drooling is a problem that can be licked !
Old 12-17-2012, 1:01 AM
I'm all for "doing it myself" but seriously, do you really think anyone would enjoy programming a large statewide trunking system with 1000+ talkgroups into a scanner using the front keypad ? That's a recipe for insanity. This is a situation where software is an absolute necessity and not simply a convenience.
Old 12-17-2012, 1:18 AM
gewecke's Avatar
Thumbs up
Well said, and exactly my view as well but even more so, I'm not yet convinced that the PSR 800 is worth the money yet because it's too fragile and too prone to failures with it's sd card format and limited ability to field program.
73,
n9zas
Old 12-17-2012, 6:00 AM
bgav's Avatar
I don't think anyone is suggesting that he do it manually on the scanner itself. The scanner does come with the GRE EZScan software.
Too fragile? It's well made, construction comparable other consumer electronics, but it isn't ruggedized. If you don't take simple precautions, yes, you can corrupt data on the MicroSD card but the same is true of the HomePatrol.
As far as field programming, there isn't a keyboard for direct entry of a frequency. One of the things I do is create a "scratch" bank labeled "INCIDENT" (right below "ALL" in my scanlists) that I add TGs & channels related to an incident into. They can be from existing scanlists or the full database. Pretty quick to do, then I only monitor the INCIDENT scanlist during an incident, and it also makes it easier to turn on recording for those channels/TGs. Then I clear out the INCIDENT scanlist when the incident is over.
This is something fairly easy to do that I learned how to do myself by reading the manual, learning, knowing and understanding the features of my scanner. If someone had preprogrammed it for me I wouldn't understand how scanlists and the Object Oriented memory management works. It's a very powerful and flexible feature once you understand how to take full advantage of it. That only comes by learning it and using it.
The best person to optimize and setup your scanner for your listening habits and preferences is you.
