I have had very good luck with: angledcables.com
You can get just about any setup you would want (Up Angle, Down Angle, Right Angle, Left Angle), in several lengths (4", 12", 24", 72"). I've found the "Mini-B Extenders" to work very well. Any widely available straight Mini-USB plugs right into the female end of the extender with a positive "click" that keeps the two cable together unless significant force is used.
Ted
