Originally Posted by bernie1661
Is there a fix for the psr 500 so i can receive new rebanded freg.? I put new Boston ems freg from radio referance but sounds like it is off freg not clear at all
Checking the database for
Suffolk County, Massachusetts (MA), I don't see Boston EMS operating on 800MHz, only UHF conventional.
Rebanding only applies to 800MHz, not for the UHF frequencies. I believe you are referring to
narrowbanding. To monitor narrowbanded frequencies, you should change the
Modulation under the
EXPERT BELOW to
NFM. If it's still a bit quiet, try using
AudioBoost.
