Originally Posted by bfletcher
Is anyone using a specific Bluetooth adapter manufacturer/model with favorable results on the PSR-800 (for Bluetooth earphone listening)? I am trying one that works well on FM but creates some unknown issue on the MARCS 800 band, to the extent that audio is garbled. FYI, it works satisfactorily while using a mobile-mount antenna but not with a 800 Mhz antenna on the radio. Thanks
You might be receiving interference from the bluetooth transmitter itself, when the radio is too close to you?
If you figure out how to make it work right, it's a cool idea.
73,
n9zas
