| GRE Scanners A forum for the discussion of all GRE branded scanning radios and receivers. |
01-15-2013, 9:29 PM
Originally Posted by Chauffeur6
Go to Updates then Configure Proxy Server and make sure the Enable Proxy Server Support box is not checked, then try updating again.
Dear Sir, did that so many times , still get error.
I can within EZ scan - Help menue click "visit GREAmerica.com" I connect
to the website
using help menu in EZ scan click "GRE Support" I connect to the website
using help menu in EZ scan click " Visit RadioReference.com" I connect
to the website
I give up, nothing is blocking in my system (software, hardware, router)
vince48
01-15-2013, 9:44 PM
to the website
to the website
vince48
try un-installing and re-installing??
(402) 937-8578
01-15-2013, 11:24 PM
Do I have to load the 1.7 beta updates for 1.8 to work, or is 1.8 cumulative?
Uniden 396XT, PSR-800 x2 , PSR-500, BC 250D, BC 245XLT, YAESU FRG-8800. Using Freescan and PSREdit500.
01-15-2013, 11:26 PM
You can go right to 1.8
Sent from my iPhone 5 using Tapatalk
(402) 937-8578
01-16-2013, 12:41 AM
Yep! I just went from v1.6 to v1.8 with no troubles at all... EZ-Scan updated without incident as well from v1.06 to v1.08. I updated the EZ-Scan software first, followed by the firmware and lastly the DSP.
Current Station Equipment:
| Uniden BC125AT, BCD-396XT, & BCD-996XT | GRE PSR-500 & PSR-600 |
| ICOM iDAS (NXDN) Portables - Mobiles - Repeaters |
01-16-2013, 1:20 AM
Well, I can't update my 800 due to the Windows 8. I have done the fix we did on other threads but it won't update my 800's firmware.
GRE PSR-600, BCD996XT - Mobile
Win500, Freescan, ID Tracker III
01-16-2013, 1:22 AM
I updated mine on WIN8
(402) 937-8578
01-16-2013, 1:26 AM
Thanks. I'll dig a little more tomorrow.
01-16-2013, 7:46 AM
Maybe post the error msg(s) so we can help figure or what's going on.
01-16-2013, 10:05 AM
Installs went smooth as silk. Running Great
01-16-2013, 2:56 PM
So far, on this update the Loudoun Co. VA X2 system sounds great.
01-16-2013, 3:35 PM
Seems little, to nothing, done about the volume disparity between FDMA and TDMA.
Bittersweet that they've made this an offical release too. Doesn't bode well for the process of further improving things.
01-16-2013, 3:41 PM
DB Admin
Have you submitted a ticket to GRE explaining the issue?
GRE America, Inc. - Powered By Kayako SupportSuite
01-16-2013, 7:47 PM
Just wondering if you were to select Audio Boost to the FDMA-only talkgroups if that would equalize the audio level with TDMA-only talkgroups??? Don't know specifics of the system you're monitoring and if the talkgroups of interest are dual-mode FDMA/TDMA or not.
Just a thought on a possible workaround...
Pop'Comm Monitoring Station: KPC4YGG
01-16-2013, 8:04 PM
I am still seeing that they are making improvements with this release which makes me scratch my head at your post.
I am going to purchase the PSR-800 just as soon as I can.
01-16-2013, 8:18 PM
Yes they're dynamic, so any potential per talkgroup fix, would seem to be useless as it would effect both TDMA and FDMA.
Mentioned by myself and others several times during the beta testing phase, which seemed to be more than enough to get all other identified issues addressed.
01-16-2013, 8:48 PM
[QUOTE=KE5TLF;1896006]Yes they're dynamic, so any potential per talkgroup fix, would seem to be useless as it would effect both TDMA and FDMA.
Rats....
01-16-2013, 8:52 PM
I updated it and no problems at all. Of course no Phase II by me just did it for the heck of it. I didn't update on the cpuudater u1.7 I wonder the new firmware 1.8?
Dell computers SUCK! Dude you jail you can't get a dell
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800
Youtube staugfl1991
01-16-2013, 9:41 PM
DB Admin
I wouldn't rely on mentioning issues in threads on RR to get GRE's attention. If there is a known issue with the firmware, which there seems to be, create a ticket in GRE's support system and you will get a direct response from them.
