| GRE Scanners A forum for the discussion of all GRE branded scanning radios and receivers. |
01-17-2013, 2:50 PM
I did the update, I am noticing absolutely no change at all. I listen to Louduon County, VA which I receive without issue. However, Loudoun is TDMA and according to these threads the scanner should be showing D2 instead of DG. Mine still shows DG so is there a setting I am suposed to change or something else I need to do to apply the update to my scanner?
01-17-2013, 2:53 PM
DB Admin
Loudoun County's system is X2-TDMA, not Phase II TDMA. This firmware enabled Phase II TDMA decoding. D2 will only appear when decoding a Phase II TDMA talkgroup.
Your scanner is acting normally, you weren't supposed to see anything different because you're not listening to a system that was affected by the update.
01-17-2013, 2:55 PM
That's why I love this forum, question asked and answered, thank you!
01-17-2013, 3:46 PM
And no mention of a certain battery type that you must use.
Back on topic, I opened a ticket with GRE on the Phase 2 vs FDMA audio difference.
BC-210XLT
"Wise men speak because they have something to say; Fools because they have to say something."
01-17-2013, 6:14 PM
What is this, the 3rd firmware upgrade with Japan out of the picture? USA... USA... USA !!! GRE America is just awesome.
One small thing, When this scanner was first introduced the database library was 17.9 MB. It has grown to 18.5 MB. If that's my biggest problem, I've got it made.
Uniden BCT7 x 2, Uniden BCT8 x 2, Uniden BC355C x 2, Uniden BCT15X, GRE PSR-800, GRE PSR-410 x 4
Semper Fi
01-17-2013, 11:43 PM
My system is still having problems with this "Fixed a delete process bug when deleting multiple objects from the conventional channels tab", which still takes takes forever but usually doesn't get started at all. I get a box that says "Deleting channels" with a progress bar from 1 to 100 that usually freezes in between, or never begins deleting to start with. Anyone else getting this or is it a bug in my system?
Uniden 396XT, PSR-800 x2 , PSR-500, BC 250D, BC 245XLT, YAESU FRG-8800. Using Freescan and PSREdit500.
01-18-2013, 5:16 PM
Reference my above post ; This only happens when attempting to delete objects from the "scanlist" menu. When deleting from the conventional channel menu there's no problem.
01-19-2013, 9:31 PM
I can't do the update on mine. I can't get the cable/port issues to line out. I had Windows 8 on my desktop and even wiped it and went back to Windows 7. I thought it would load the drivers right up & load but no
GRE PSR-600, BCD996XT
Win500, Freescan, ID Tracker III
01-19-2013, 9:34 PM
There is a fix for this for win8. I have win8 and updated mine. There is a Thread on here about how to fix it.
Sent from my iPhone 5 using Tapatalk
(402) 937-8578
01-19-2013, 9:49 PM
I had it updating the SD card in Win 8 and doing it now in 7, but neither will do the CPU & DSP.
01-19-2013, 10:14 PM
Did you follow the steps like they showed you in that one thread?
How to install the drivers
(402) 937-8578
01-19-2013, 10:16 PM
Yes, I turned off the driver verification & all that.
01-19-2013, 10:30 PM
I guess try a different pc
(402) 937-8578
01-19-2013, 10:53 PM
I just checked and I didn't have the driver signature check disabled. It's working now.
01-23-2013, 9:44 PM
auto fill mode
"We recommend ensuring the sites on a P25 Phase 2 system be set to Auto-Fill mode. This will allow the scanner to automatically set the information needed to track the system from the control channel data stream. Don't use "custom tables" for Phase 2 systems unless you really know what you're doing." Im unsure how make sure the system is set to auto fill mode. Currently Philadelphia is the only P25 around me and want to make sure its right. thanks in advance.
01-23-2013, 9:48 PM
Please Direct your question to the Pennsylvania/Philly threads for specifics on your radio/location.
>>>AR8200MKIII-DJG5-PRO106-PSR310-PSR800<<<
01-24-2013, 7:25 AM
Unless you change anything for the site(s) manually, it should be set to "Auto Fill" by default.
01-29-2013, 11:01 AM
Win 7 Home Premium 64 bit SP1 + PSR-800
I had difficulty updating my PSR-800 as well from 1.7 to 1.8 using Win 7 64 bit. I’m posting this here in case it helps anyone else.
I talked to GRE and a tech walked me through things. With the message “no scanner port detected” he was certain that the error was on my end. Although the computer itself said it had the latest version of Win 7 64 bit SP1 (there is no SP 3 for 64 bit, according to Microsoft) I ran Microsoft updates anyway an found that I was 3 updates out of date.
Note that I also have the proxy server option set to “off” as this helped some people, but I don’t know if it helped in this case because it made no difference prior to running Win Update. Note also that I didn’t disable automatic driver checks on my system.
After letting Microsoft Update run all 3 of these updates and reboot, the scanner communicated with the computer in an apparently correct fashion, recognized that it was there, and allowed me to update to v1.8 via EZ Scan.
After restarting the scanner it seems to work as intended. We’ll see if any communications problems develop later down the road but for now I would suggest running Windows Update to make sure your copy of Win 7 is actually where it is supposed to be in terms of the latest updates.
