Old 01-25-2013, 1:04 PM
chanman13's Avatar
Default Latch LED
Have had my PSR-800 for a month and tweaked the hell out of the settings. On the LED options screen, the "Latch LED" option what does that do? Very curious about it.
RS pro-163 GRE PSR-800 x2,
Old 01-25-2013, 1:20 PM
Latch LED: When set to 'On', the Alert LED will remain in the LED Mode after the transmission is complete or until it is overridden by the next object that is also using an Alert LED. Default is Off.
Old 01-25-2013, 9:30 PM
Anytime you have a question like that, try it and see what happens. That's a quick and easy way to learn new things about your scanner and you won't hurt anything. Just keep a working copy of your settings on another microSD card.
