  #21 (permalink)
Old 02-16-2013, 12:14 PM
Originally Posted by command_z View Post
I wonder if this one has an amp bulit in? I assume so since the ebay listing says it has 12v DC input.
Speco Speaker Communications Extension CBS 240 | eBay
You think this would be loud enough in a car? THANKS!
Yes I use this unit. It is amplified. Running the PSR800 at volume level 15 will be plenty loud. You do have to buy a cigar lighter plug though. It does not come with that.
  #22 (permalink)
Old 02-16-2013, 1:47 PM
Thank you. I just purchased one. I may wire it directly to the fusebox so I can keep the cigarette lighter free to power the PSR800.
  #23 (permalink)
Old 02-16-2013, 3:17 PM
I got a FM transmitter (sold for Ipods) and have the 800 audio coming out o f my car stereo speakers
I rarely listen to the car radio anyway
  #24 (permalink)
Old 02-16-2013, 6:36 PM
You will not be disappointed. It is well built, quality speaker. I have to get mine connected up to the fuse box also. Just have not had time.
  #25 (permalink)
Old 02-17-2013, 12:00 PM
Question External speaker
Hello I also have the radio shack amplified speaker doesnt seem to be loud enough is there some setting I am missing. Thanks for any advice.
  #26 (permalink)
Old 03-03-2013, 1:53 AM
mike_s104's Avatar
Default Re: Psr 800 external speaker choices
Advise: read above
  #27 (permalink)
Old 03-17-2013, 12:09 PM
md_p97's Avatar
I didnt see this thread previously.
I posted on a radio shack mini amp here:
PSR 800 audio issue fixed
PSR-800, PSR-600, Pro-106
RS 97, 2067, 2052, 2055, and 96
BC 150, 80, RS Discone
Austin Spectra on the Jeep
  #28 (permalink)
Old 03-17-2013, 12:23 PM
I bought this one. When it arrived I found out that it was not amplified. The volume was very quiet.
I think I may need an amp.
  #29 (permalink)
Old 03-17-2013, 2:37 PM
Did you buy the AES-4? It most certainly is amplified. Using a PSR 800 volume settting of 15 will be plenty loud. Above that setting gets extremely loud. Perhaps you got a defective unit.
Products
  #30 (permalink)
Old 03-22-2013, 4:53 PM
The best answer to the low volume with the earphone jack problem is to bypass the resistor that lowers the signal level at the jack. Easily done on most scanners, like I did on my GRE/RS PRO106, Uniden BC235, etc.
I haven't opened up my PSR800 yet to look, but considering the "high tech" design of the radio, I'm wondering if they might use an attenuation method other than a simple resistor. The fact that the radio reports the jack is being used makes me wonder. Anyone disected their radio yet??
