Originally Posted by wmetech1
Coming from a Pro-164 myself, if you could program a scanner before, the 800 will be a piece of cake. All the channels and trunk systems are imported from the RR database to the software, then you click to transfer the configuration to the scanner's SD card.
I assure you, you will not be disappointed with the purchase.
While it is a piece of cake..............................it is a totally different way of programming that makes some people go nuts
read the threads,,,,,,,,,,ALL of them
Read the manual.............................all of it
It will do only what you program it to do
