Old 03-02-2013, 4:49 PM
Default Scanner on the floor
Found my PSR 800 scanner on the floor this morning. Not sure how but it fell from about 3ft. Won't turn on.. nothing.
Old 03-02-2013, 4:52 PM
thebigphish's Avatar
...open it up and look?
Old 03-02-2013, 5:17 PM
#1 Did you have the usb plug in?
#2 Take the batterys out and let it set for 5 minutes
#3 Put batteries back in and try again
Old 03-02-2013, 6:03 PM
It wasn't plugged in and thanks for advice with the batteries. Someone mentioned opening and looking but not sure about that.
Old 03-02-2013, 7:01 PM
gewecke's Avatar
Thumbs up
NOT a good idea unless you are well trained in SMT and electronics at the board level!
Just opening the case improperly can further damage the radio.
73,
n9zas
Old 03-02-2013, 7:18 PM
Thank you! Removing the batteries did the trick. Wasn't looking forward to sending it for repair.
Old 03-02-2013, 7:31 PM
The batteries don't really fit "tight" and are easily shaken loose.......................yea mine has dropped a couple times
The plug also tends to break off if dropped (also known by experience)......
I always reset the batteries first when the radio messes up...........................99% of the time it works
Old 03-03-2013, 10:46 AM
TedRHayes's Avatar
I've had similar issues. Sometimes it is also useful/necessary to re-seat the MicroSD card.
Old 03-03-2013, 10:51 AM
BTDT too............
