Old 09-26-2013, 7:13 PM
kg4ivt's Avatar
Default PSR 500 Belt clip?
Are belt clips for the 500 unavailable now? I've called the number that's been posted on this forum along with emailing GRE and haven't received a response. Does anyone know of another way of getting ahold of a replacement belt clip?
Thanks!
Old 09-26-2013, 7:25 PM
Thanks!
Wait a few months until Whistler/GRE gets rolling -----Maybe they will re-open the GRE office that has been empty for several months
Old 09-26-2013, 11:18 PM
mine cracked and i had to fix it with epoxy,
Old 09-27-2013, 3:21 PM
krokus's Avatar
Default Re: PSR 500 Belt clip?
The "old" GRE has left the radio market, and the facility closed. Whistler was mentioned, due the recent announcement that Whistler has purchased the rights to the GRE stuff, and is entering the scanner market.
If you cannot wait, you could try ordering the belt clip for a RadioShack Pro-197, which uses the same clip. ScannerMaster offers a leather case for the radio, which has a clip, too.
Old 09-27-2013, 4:06 PM
@Krokus
ya mean pro 106 belt clip, The 197 is the base/mobile
Old 09-27-2013, 5:18 PM
Ronaldski's Avatar
Mid-MI DB Admin
From,
PSR-500 Belt Clip
Look at PSR-500 Belt Clip
PSR-500 Belt Clip
Another http://www.scannermaster.com/RadioSh.../01-581339.htm
Old 09-28-2013, 6:59 AM
krokus's Avatar
Originally Posted by puzzleriddle View Post
@Krokus
Whoops. Yeah, that one.
Was trying to type that out in a hurry.
Old 09-28-2013, 9:20 AM
kf7yn's Avatar
There is one on eBay but at an insane price.
Jon - KF7YN
Old 09-28-2013, 10:12 AM
Have you tried Rat Shack?
Old 09-29-2013, 11:16 AM
NWI_Scanner_Guy's Avatar
$39.99?? Yep, that's insane.
Just wonder if anyone is equally insane to pay that much for a belt clip?
Ham: FT7900R / TH9000 / KG-UVD1P / UV5R / UV5RCX / UV3R
Base/Mobiles: BCD536HP / HP1(E) / BCD996XT / BCT15X(x2) / BC355C
Handhelds: BCD436HP / BCD396XT / BC346XT / PSR800 / PSR500 / PSR310 / PRO107
Old 09-29-2013, 11:34 AM
rgchristy's Avatar
Hi, This is the closest thing I've found so far. I bought it on ebay. Here's the link:
Motorola Radio Clip HLN9724A P1225 P1225 LS SP50 GP300 GP350 GTX Ltr P110 Belt | eBay
I had to make a few modifications with a small, fine hobby file and you have to go slowly and only remove a tiny bit at a time, so you don't overdo it. So far, it works on my 310, 500 & 800.
Take Care,
Rich C
Old 09-29-2013, 2:31 PM
oesjmr's Avatar
My clip broke a couple of months ago. Everywhere I checked was out of stock, so I just ended up ordering a leather case for it.
PRO-95 | PRO-106 | Yaesu FT-60R | Anytone AT-5888UV
Old 10-01-2013, 6:29 PM
radionut44's Avatar
Get a Motorola clip # NTN8266B. It slides in perfectly. There is a small hole in the retaining spring. Drill a hole that size and location in the case. Put a 4/40 x 1/4" screw thru the hole from inside the radio case, a nut on the back side of case to hold it in. Then slide the clip in place and let the hole in the spring go over the screw. It is a great clip and you can easily remove if you want to. No fileing was required.
Old 10-02-2013, 3:32 PM
krokus's Avatar
Did you mean that small, triangular hole? Where did you drill the hole?
Old 10-02-2013, 5:39 PM
The cheap plastic clip on my 164 broke off one night so I bought a metal one from http://TheClip.com. Had to do a little engineering but its held on with 4 slothead bolts and it will NOT ever come off unless you want it off. Cheap prices, quick shipping. Not bad. Beats plastic.
When fuses go to work, They quit.
Old 10-02-2013, 8:02 PM
kg4ivt's Avatar
Thanks everybody. Looks like I'll be giving the Motorola clips a try.
And yeah, $39.99 is ridiculous for a belt clip.
Old 10-04-2013, 12:30 AM
mikepdx's Avatar
The belt clip for the PRO-97, and also the PSR-500,
is Radio Shack RSU part number 12418273.
You have to order it at your local store.
- sent from my Commodore 64
Old 10-05-2013, 6:43 PM
radionut44's Avatar
Krokus, just saw your post...sorry for delay. With the clip slipped in place scratch a mark through the triangular hole you pictured. Then drill a hole in the back of the case at the location of the scratch mark. That will be the hole for the 4/40 screw.
