Old 11-02-2013, 4:50 PM
c5corvette's Avatar
Default PSR800 mini usb not functional
USB connection stopped working on my PSR800. I have checked this message...
Mini USB connector PSR800
... I tried to take it apart and look into the problem and it went from intermittent to never works.
Unit still works fine with batteries, but I can't connect to computer or charge the batteries!
Whistler doing warranty repairs yet? Anyone working on these things - please IM me.
FREE Interop:
1. Pre-program agency radios with all national interoperability channels and frequencies.
2. Share radio frequencies / talkgroups with neighboring agencies on compatible radio systems.
Old 11-02-2013, 5:57 PM
dkf435's Avatar
If you could find a good tech around there and the traces are not ripped off the board it would probably be reflowing the solder and adding a bit.
David Kb7uns
AR3k,AR5k,AR8k,AR82k,AR86k,SDU5k,SDU55k,ARD25 R10,R20,R71,R72,R75,R7k,R71k,R85k, PCR1k,PCR25k,R2500 PSR500,PSR600,PSR800 RS26,94,97,2035,2055,106,197 760xlt,245XLT, 796D,996T,996XT,396T,396XT,HP1,HP1E
Old 11-02-2013, 6:24 PM
c5corvette's Avatar
If I had to guess, after opening it up, the socket is actually soldered to the board fine and the inner part of the socket is damaged.
Where can we send these to be fixed?
FREE Interop:
Old 11-02-2013, 6:32 PM
scosgt's Avatar
At this point you really have no need to connect to the computer. There are no more firmware updates, and you can do everything with the card. Charging in the radio is a bad idea anyway.
Old 11-02-2013, 8:10 PM
right now------------------------------no where.
Wait a bit until whistler gets up and running -----------but don't expect WARRANTY repair.
Old 11-02-2013, 8:15 PM
c5corvette's Avatar
I entered everything from a certain zip code into the scanner on a recent trip and I don't know how to delete it without using the computer - can you tell me how to do that?
FREE Interop:
Old 11-02-2013, 8:27 PM
Take the SD card out of the scanner and use a card reader to transfer the data in and out of the card with the computer.
Old 11-02-2013, 9:16 PM
Not necessarily correct answer. What about those of us that actually power the radio via the USB port which is the way to go when used mobile based on how the radio eats batteries. IMO he needs to have a functioning USB port.
Old 11-03-2013, 1:29 AM
dkf435's Avatar
If you go on ebay and search some you will probably find the same style of jack but you will need somebody that is good at soldering as you do not want to toast or lift traces. Must also be careful with amount of solder used so not to bridge the pins.
. Was in Goodwill the other day and found a mini USB right angle cord and it will be going into the Jeep for mobile use of the PSR800 to make sure this does not happen here.
David Kb7uns
Old 11-03-2013, 4:04 PM
But the answer is TECHNICALLY correct..................power from a source other than battery is not NECESSARY
Old 11-03-2013, 4:06 PM
Take the SD card out of the scanner..............and use the computer to make your changes
Save your changes back to the card and re-install it in the scanner
you might have to read the card into the EZScan program then make the changes you want----then save the changes back to the card
Old 11-04-2013, 11:05 AM
scosgt's Avatar
I get six hours out of batteries. A spare set will do for an entire day of driving.
