  #21 (permalink)
Old 07-09-2014, 9:47 AM
What Gre software version are you using? I would program it for you but I think the gre 500 software is different.
  #22 (permalink)
Old 07-09-2014, 9:53 AM
My software is ARC500. Doubt it will work. I would Google and Bing every driver possible and download them. Pain in the rear but necessary when a company is destroyed by a title wave.
Other possibilities. Contact Whistler. Alinco repaired my 500. They might know which driver.
  #23 (permalink)
Old 07-09-2014, 11:07 AM
Wiki Admin Emeritus
Originally Posted by KW4HKY View Post
Google it. Free software. Works on uniden. No clue if it works on gre.
FreeScan does NOT work on GRE scanners....Mike
  #24 (permalink)
Old 07-09-2014, 11:08 AM
adams_jb's Avatar
Question Maybe this will work??
I am having the same problem with my PRO-18 scanner. I found this download on Radio Shack download website. I am going to try it tonight.
RadioShack® USB-PC Interface Cable for GRE Scanner
USB Scanner Programming Cable
Both are downloads.
RadioShack.com
  #25 (permalink)
Old 07-09-2014, 11:10 AM
  #26 (permalink)
Old 07-09-2014, 1:23 PM
I am using version 1.08 of the Grecom psr800 software.
  #27 (permalink)
Old 07-10-2014, 1:40 PM
Any luck?
  #28 (permalink)
Old 07-10-2014, 2:01 PM
Any luck?
Not with a Win 7 machine.
I've been using my old school 32 bit XP with SP3.
  #29 (permalink)
Old 07-10-2014, 4:44 PM
None of the suggestions worked for me. Friend of mine is going to buy my scanner. Think I will look at the Bearcat 436HP. Might be a bit easier to use and hopefully no issues updating.
  #30 (permalink)
Old 07-10-2014, 6:33 PM
KB0VWG's Avatar
Smile It could be a comm port mix up
Have you checked the device manager and checked on the comm port? The scanner could be looking for one port while the pc wants to use the other port. You can change the ports in the device manager.
kb0vwg
wqoi992
  #31 (permalink)
Old 07-11-2014, 7:41 AM
I keep my Vista machine around for a reason
  #32 (permalink)
Old 07-11-2014, 8:17 AM
kb0vwg
wqoi992
If the OS does not recognize the device via the USB cable then there will be com port assigned.
I see the 800 in device mgr as unknown and have tried many ways to load the driver and it does not like it.
I've removed the device, re-installed.
  #33 (permalink)
Old 07-11-2014, 8:51 AM
Just a thought (I don't use Windows 8) but can you run EZScan in Win 8 as a Windows XP compatible program and if so will it then recognize the scanner?
  #34 (permalink)
Old 07-11-2014, 12:34 PM
adams_jb's Avatar
Question No good
Both are downloads.
RadioShack.com
These did not do anything for me, I will keep looking.
  #35 (permalink)
Old 07-11-2014, 1:31 PM
They are worth a try. I'll do the same over the weekend and report back.
  #36 (permalink)
Old 07-11-2014, 1:36 PM
The USB file is the same one found on the GRE site and does not work. The other is a scanner interface program and there is a new update.
  #37 (permalink)
Old 07-11-2014, 1:54 PM
Default GRE 800
No driver is needed because the cable is a regular USB type. There is no chip involved. I just loaded the software onto my Win 8.1 machine, plugged in the scanner with a stock USB cable and it works perfectly.
  #38 (permalink)
Old 07-11-2014, 2:37 PM
I thought the same thing but what would cause any Win 7 64 I've tried machine not to see the PSR-800 and it shows up as an unknown USB device ?
1. Should I install the EZ software first, launch, then plug the USB cable with 800 attached ??
OR
2. Install the USB cable with 800 attached, then install the EZ software ??
Why doesn't it see the device ?
Thanks.
  #39 (permalink)
Old 07-11-2014, 4:39 PM
I thought the same thing but what would cause any Win 7 64 I've tried machine not to see the PSR-800 and it shows up as an unknown USB device ?.
I use one of any of the 5 or 6 cables I have that fit the scanner when I hook it up.................I bought them off of Ebay because of the angle of the mini USB connector & the way it inserts into the scanner
I have never found a cable that won't work
you are having a port problem not a cable problem
  #40 (permalink)
Old 07-22-2014, 2:48 PM
Originally Posted by ScannerSK View Post
I noticed at the bottom of the GRE Download Website <http://www.greamerica.com/support/> there are two USB PC/IF Datacable 30-290 Drivers. I’m not sure if they would help in your situation or not?
By “new LT” are you referring to a GRE PSR-800 scanner?
Shawn
Already tried this as well.
Still no luck with Win 7, still using XP 32bit machine.
Any more ideas ??
