Old 07-21-2014, 6:27 AM
Default PSR-800 Error
so my scanner had been working fine... then all of a sudden to day I get a message...Fatal Error data files not valid...
not sure what this is or what caused it...
any help or suggestions
I fight fires because the voices in my head tell me to.......
Old 07-21-2014, 7:44 AM
troymail's Avatar
Depends on exactly what error you are seeing.
Probably an SD card failure or other related issue Try reformatting the SD card and/or trying a different SD card.
Unication G5(UHF)
Old 07-21-2014, 8:10 AM
Do you get the error when you use your back-up SD card? If so then you may have a problem with the scanner.
Old 07-21-2014, 10:18 AM
it turns on fine...and goes thru a cycle or 3 of scanning then the message fills the screen....fatal error data files not valid
but when I try and use ezscan it isn't connecting to any severs to update...
Old 07-21-2014, 6:27 PM
When prompted skip the update this time and then try to format your SD card
Old 07-21-2014, 8:00 PM
NWI_Scanner_Guy's Avatar
I read on the Yahoo PSR-800 group that the servers are being transferred from GRE to Whistler and will be down for a few days.
PRO-2051 / BC-355C
BCD436HP / BC-246T / BC-125AT / PRO-137
Alinco DR-605 / UV-82X / UV-82HP / UV-3R+ / JT-UV71
Old 07-22-2014, 4:20 AM
thanks everyone for the suggestions....
