darrylcn
Thought I would check here in case anyone knows a solution. It may be the system's fault, not my scanner's but here goes:
Periodically (less than 1-3 times per day on avg I think) my scanner will play audio from a talkgroup which is not programmed or at least not being scanned.. For instance I'll be scanning and it will stop on a police talkgroup and I'll hear audio from say EHS or a garbage company. To put it more simply, I don't even need to be scanning for this to happen, I could be paused/stopped on a talkgroup, and I'll hear someone else on our trunking system key up and transmit. This always coincides with traffic on the talkgroup I have scanned to and stopped on. It's like two users are keying up at the same time, and my scanner is choosing the wrong voice channel to play out the speaker. I've never heard a user comment when this happens so it may be on my end. Does this make sense, and if so, does anyone have any thoughts on a fix? Thanks.
