hey guys, i loaded up my libraries. Some TG were X'ed out but i used the bypass option to load enc tg. I changed ENC to noise so i can hear the garble. The TG arent locked out, their mode is correctly set. The only way that I can hear an enc TG is if i use a limit scan and pick up a repeater as it is transmitting an ENC TG. I have tried everything and my scanner will not pick up an ENC TG. i use these for experimenting and logging data. Ive even gone as far as limit scanning and then catching the TG transmitting. then quickly jumping over to the TG by browsing objects and its like the TG is dead. anything? using latest FW
