GFerg1919
Are there any other cases available for this radio other than the one Scanner Master sells? I would like a regular drop in type case, not the one with the flap and the snap that is sure to scratch up the case by the speaker. Also would prefer the belt clip was part of the case, not using the one on radio.
The case for Pro 106 lines up great on the front. The radio will fit with the belt clip removed, but is about a quarter inch too loose front to back and the USB port does not match up with the holes on side.
Any suggestions?
Any suggestions?
