tampatracker
- Joined
- Dec 9, 2007
- Messages
- 1,241
Hello again. When I'm in the advanced tab and using the scan set feature the program will not go into the secondary window that pops up upon clicking on a scan set which then wants to know which scan lists are to be included in that set, as indicated by their respective check boxes. I have tried with both the scan mode setting both on and off. I have uninstalled and reinstalled the EZ 1080 software with no luck, and while doing the same thing using GRE's EZScan there is no problem at all. Any ideas? T.I.A. - T.T.
