Just cause we (myself and fellow RR member VE6RHS) had time .. and I love numbers, here is my Scanner Sensitivity Shootout .
Scanners tested - Whistler WS-1080, GRE PSR-800,GRE PSR-500 and Uniden BCD436HP.
These were the 4 scanners we own amongst the 2 of us.
They were tested with identical procedures using the same equipment, connecting cable etc. We used a Ramsey com3010 service monitor for this test.
We tested for "minimum squelch sensitivity" ... on the 5 frequencies listed below.
Minimum Squelch Sensitivity is ... "The minimum received signal strength level which unsquelches the radio ..."
The results are as follows .. (* denotes most sensitive for frequency)
Whistler WS-1080
155.0 - 0.16 uV
447.0 - 0.23 uV
465.0 - 0.21 uV *
770.0 - 0.23 uV
868.0 - 0.23 uV
GRE PSR-800
155.0 - 0.15 uV *
447.0 - 0.20 uV *
465.0 - 0.24 uV
770.0 - 0.13 uV *
868.0 - 0.19 uV
GRE PSR-500
155.0 - 0.20 uV
447.0 - 0.26 uV
465.0 - 0.34 uV
770.0 - 0.16 uV
868.0 - 0.17 uV *
Uniden BCD436HP
155.0 - 0.24 uV
447.0 - 0.27 uV
465.0 - 0.24 uV
770.0 - 0.29 uV
868.0 - 0.40 uV
Thanks .. hope that gives you a better idea how these scanners may perform.
Whistler WS-1080
155.0 - 0.16 uV
447.0 - 0.23 uV
465.0 - 0.21 uV *
770.0 - 0.23 uV
868.0 - 0.23 uV
GRE PSR-800
155.0 - 0.15 uV *
447.0 - 0.20 uV *
465.0 - 0.24 uV
770.0 - 0.13 uV *
868.0 - 0.19 uV
GRE PSR-500
155.0 - 0.20 uV
447.0 - 0.26 uV
465.0 - 0.34 uV
770.0 - 0.16 uV
868.0 - 0.17 uV *
Uniden BCD436HP
155.0 - 0.24 uV
447.0 - 0.27 uV
465.0 - 0.24 uV
770.0 - 0.29 uV
868.0 - 0.40 uV
