Ed6698
There is a new Firmware update 2.7, for the WS1080. I see this has already been posted so this post can be deleted.
This Firmware update 2.7 was to boost the Analog frequencies and the Abst function so one analog channel can sound like the next
similar to a AGC on older scanners. It isn't anything close to a normal Automatic Gain Control like that on my old Pro96 where ALL channels get a gain/boost and sound the same.
You'll only hear a difference if you have "ABst" turned on for analog channels / talkgroups. Version 2.7 only fixes a bug where the user's ABst setting was not always applied for analog.I have done the firmware upgrade and I hear no difference at all.
What Whistler needs to address for a real update would be a fix
for the fact that P2 comms are much louder than P1 and analog.
They need to turn down the volume on P2 and all would be good.
Uniden doesn't have this huge difference between P1 and P2 volumes
but if they did uniden scanners can set the volume levels up or down per channel.
something Whistler/Gre scanners lack. However Uniden is way behind in the RF sensitivity area
so you just can't get everything in one scanner.
