For those with the PSR-800 and it's Radio Shack/Whistler clones, how easy would it be to change scanlists on the fly with the 1095, while mobile, for example, without a full keypad?
John
Peoria, AZ
I have both the WS1080 and PSR-800 and what I do is use Scan Sets. I've created a Scan Set for each of the different Counties I'll typically drive through. In each County's Scan Set I've included all the Scan Lists I monitor for that County. Now all I have to do when driving around the state is just toggle on/off the different Scan Sets.
Typically, it goes like this...
Press the Menu key twice (need to be sure I'm on the right menu).
Press the Down key seven times for the WS1080 or six time for the PSR-800 (the menus are different).
Press the Right key.
Now the scanner displays a list of all my Scan Sets. Now...
Press the Down key 1,2,3... times to get to the County I want to toggle.
Press the Sel key to toggle on/off this Scan Set.
I do the above two steps twice, once to toggle off the current Scan Set and again to toggle on the new Scan Set. Once I've toggle all the Scan Sets I need...
Press Left to go back to the Main Menu. By default the scanner will be at the Scan option.
Press Sel to continue scanning.
Yes, it seems like a lot of steps, and it is. But it's a lot less then scrolling through all the different Scan Lists (I have about 120 Scan Lists programmed). And I've also learned to do it without looking at the scanner (e.g., not taking my eyes off the road).
