I have had not a great deal of success trying to find a SD card that will work properly with the WS-1095. (other than the stock one)
Either the card will not work at all .. or there will be skipping of words when playing audio in the 1095. This is not a problem with the scanner .. but the card. Lets face it .. some cards work, some don't.
So .. because I cannot buy a ton of cards at random to see if they work, I am hoping to find what other 1095 users are using.
The stock card works 100% properly from my testing .. but they are of an older flavor. As such they are hard to find and can be only found on Ebay from what I have seen.
Just a note .. I have tried "Prepare Scanner Memory / SD Card for use" .. as well as the "SD Formatter" application. Some cards simply will not work no matter how you try to format it.
For the benefit of the community .. a picture is worth 1000 words. If you can attach a pic of your card that would be great benefit but of course optional.
I have attached my SanDisk card that does work .. but the audio is often choppy and there are missed words.
