In anticipation of a 1095 that should arrive in the next day or two from the Ham Station, I have pulled out my 1080 for the last few days and been using it more. Two systems I monitor quite a bit are Long Beach Police/Fire, which uses DCS, and the CHP, some channels which use CTCSS.
I get a very loud squelch tales on most of the Long Beach and a few of the CHP stations that is really annoying. When I listen to the same channels on my 325P2, 996P2, 436/536HP, or even the newer PRO-651/652, I get none of these squelch tails. Moreover, even on the 1080, I don't have that much problem on some other systems/channels with CTCSS.
I also experience the same squelch tails on the PRO-668, so this seems to be a problem I have with the PSR-800 type scanners. Is there some setting I a missing to fix this squelch tail problem. Thanks for any responses.
