matthias_h
- Joined
- Jul 10, 2013
- Messages
- 24
Windows 10 installation of GRE PSR-800 software and driver
Windows 10 update from 1511 to 1607:
EZScan needs to be uninstalled, EZ Scan folder removed in "My Documents", reboot, then follow below procedure.
This procedure requires administrator privileges and connection to the Internet
1 - Download EZScanDGInstall_v1.08 from the greamerica.com web site, save it in a folder (e.g. named GRECOM) and unzip it in that folder. EZScanDGInstall_v1.08.exe will be created.
2 - Instruct Windows to boot into the "Options" menu. Either click on the "Power" button, hold down the "Shift" key while clicking "Restart or Run: shutdown.exe /r /o /f /t 00
3 - After rebooting into the “Options Menu”, click “Troubleshoot” and then “Advanced options”.
4 - On the next page, select "Advanced Options".
5 - Select the "Startup Settings" to change the behavior of Windows Startup and then click restart or reboot on the next page.
6 - A menu with 9 selections will appear. Select number 7 or F7 to "Disable Driver Signature enforcement".
7 - Windows 10 will restart.
8 - Install the EZScan software by running the downloaded and unzipped EZScanDGInstall_v1.08.exe .
9 - Run the installed software and update it from inside to 1.9 Bld 301.
10 - Connect your PSR-800 scanner to the computer. Wait for the default driver installation, which is completed when a file explorer window with the scanner SD card contents pops up.
11 - Now correct the scanner driver. In the Device Manager, find the extra USB Communications Port assigned to the scanner under "Ports (COM&LPT)".
12 - Update the driver with this special procedure: "Driver" tab, "Update Driver", "Browse my computer for driver software", "Let me pick from a list of device drivers on my computer", "GRECOM PSR-800 Serial Device", "Next".
13 - If "GRECOM PSR-800 Serial Device" is not shown then go back one screen and select "Browse for driver software on your computer", type this file path: C:\Windows\Inf\GRECOM_PSR-800.inf and click on "Next".
14 - If a warning screen about the risk of unsigned drivers appears, select the unsigned driver option because the PSR-800 driver is unsigned.
15 - Repeat the PSR-800 driver installation steps 10 - 14 for each physical USB port on your computer.
16 - You can verify the driver installation by checking in the device manager that now your scanner shows up under "Ports (COM&LPT)" as "GRECOM PSR-800 Serial Device".
