  #41 (permalink)
Old 12-24-2016, 7:43 PM
W4KRR's Avatar
Originally Posted by Homeboys-Scanna View Post
Is there any way to take your PSR-800 codeplug and re-load it into the PSR-800 with the WS-1080 EZ Scan software after you do the flash upgrade? Or do you have to manually re-program the radio with all your systems and objects from scratch again? Thanks.
Use the PSR-800 EZ Scan software to save your current configuration to a file. Then once you upgrade, use the EZ Scan software intended for the WS-1080 to open the configuration file you saved from the PSR-800. I actually opened a file that was saved from my TRX-1 using the WS-1080 software; it worked just fine.
The upgrade shouldn't erase you current configuration anyway.
Ken
  #42 (permalink)
Old 12-24-2016, 7:53 PM
Homeboys-Scanna's Avatar
Understood, thanks. It looks like you save the configuration as a .zip file by going to File > Save To Archive in the PSR-800 EZ Scan software. Then you get a file directory prompt where you want to save the .zip file to. Then you open the WS-1080 EZ Scan software and go to File > Restore Configuration from Archive. Then you get another directory prompt where you can select the .zip file you saved and then click Open. The WS-1080 EZ Scan software loads the codeplug and you're all set!
Under the Advanced Features tab in the WS-1080 EZ Scan software, I went ahead and set the Charge Hours drop down menu setting to Disable, to disable the Battery Charge Option.
"Copy, 132 and Bush, cover's code 3."
  #43 (permalink)
Old 12-24-2016, 8:09 PM
Hello,
Other people could likely comment on this better as my experience is more incremental.
I do not think there is any problem upgrading the firmware and using the WS-1080 Ez-Scan to read the configuration back into the WS-1080 Ez-Scan program. People have even used the WS-1080 Ez-Scan program with the PSR-800 using stock PSR-800 firmware. I would check the settings in the WS-1080 Ez-Scan program and make sure they are set correctly. I would also recommend the Battery Charging be turned off because the PSR-800 charge circuit is different than the WS1080. Battery charging in the scanner is not very good anyway.
I suspect that the same basic file formats are used between scanners with additional values for the added modes. I had DMR channels programmed into my Pro-668 when I went back to the stock firmware. The scanner still worked on non-DMR channels, but beeped during powerup. It likely beeped because the stock firmware did not recognize the values used for DMR channels. It appears there are only one set of RRDB files that are downloaded. Either the PC App or the scanner filter unsupported system types.
73 Eric
  #44 (permalink)
Old 12-24-2016, 9:16 PM
bravo14's Avatar
I have downloaded the whistler 1080 software and I see Version 2.17 will this work on the 800?
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800 BCD536HP BCD436HP HomePatrol-1
YouTube http://www.youtube.com/user/staugfl1991 (videos)
YouTube http://www.youtube.com/user/scannerfreak91 (Scanners)
  #45 (permalink)
Old 12-24-2016, 9:20 PM
trp2525's Avatar
It will work with your PSR-800 once you have "converted" your PSR-800 to a Whistler WS1080 by using the firmware tool.
trp2525
RCA 16S400, Regency HX1500, PRO-2006, PRO-197, PRO-668 (officially upgraded to WS1080), TRX-2, BC950XLT, BCD996XT, BCD396XT, Motorola Minitor II, Antenna Specialists MON731
  #46 (permalink)
Old 12-24-2016, 9:22 PM
bravo14's Avatar
Thank you.
  #47 (permalink)
Old 12-24-2016, 9:26 PM
W4KRR's Avatar
And once you're done with the updating, the WS1080 programming software should reflect a CPU Firmware version of 3.8 and a DSP Firmware version of 3.0, under "Updates", "Check for all Updates".
Ken
  #48 (permalink)
Old 12-24-2016, 9:38 PM
bravo14's Avatar
I plug in the usb in the computer than into radio than I hit power button and menu button at same time and it turns radio on is there a step I missed?
  #49 (permalink)
Old 12-24-2016, 9:43 PM
W4KRR's Avatar
That should put the radio in firmware update mode; screen shows current CPU and DSP version.
Ken
  #50 (permalink)
Old 12-24-2016, 9:45 PM
bravo14's Avatar
It won't show the CPU and DSP. I'm on step 1 and it won't let me pull nothing up. Do I need to take out the batteries while using the usb cord?
  #51 (permalink)
Old 12-24-2016, 9:48 PM
bravo14's Avatar
I got it pull up. I forgot to hold down the buttons while putting the usb cord in lol.
  #52 (permalink)
Old 12-24-2016, 9:50 PM
W4KRR's Avatar
Is the GREFwTool program running? In settings, is scanner set to PSR-800 and firmware set to WS-1080? Try this:
With the scanner powered off and unplugged from the USB, put the scanner in CPU Update mode. This is done by pressing the Menu button on the scanner and plugging the scanner into the computer while holding the Menu button. The menu button is released after the scanner is plugged into the computer and the computer detects the scanner.
Ken
  #53 (permalink)
Old 12-24-2016, 9:55 PM
bravo14's Avatar
I have the greefwtool running I got the firmware updated
  #54 (permalink)
Old 12-24-2016, 10:04 PM
W4KRR's Avatar
Make sure you use the WS-1080 EZ Scan software to update the DSP to version 3.0. DO NOT attempt to update the CPU with the EZ Scan software, just the DSP. When done, the DSP version should be 3.0 and the CPU should be 3.8. And the scanner should boot up with the Whistler logo.
Ken
  #55 (permalink)
Old 12-24-2016, 10:10 PM
bravo14's Avatar
I hit Menu and left the boot menu and went to the software and went to update DSP and sits there.
  #56 (permalink)
Old 12-24-2016, 10:14 PM
W4KRR's Avatar
What DSP version does it show that you have now?
Ken
  #57 (permalink)
Old 12-24-2016, 10:23 PM
bravo14's Avatar
I'm stuck on this DSP update. I turn off radio unplug cable than plug usb in and hit menu while usb is going into radio and I went to software go to update DSP and says exiting takes a mint than says radio not connected.
Boot Ver:F1.0
appl Ver:u3.8
  #58 (permalink)
Old 12-24-2016, 10:35 PM
bravo14's Avatar
It shows I have updated it. I'll do some tests on DMR and DMR Trunking
  #59 (permalink)
Old 12-24-2016, 10:37 PM
W4KRR's Avatar
Boot Ver:F1.0
appl Ver:u3.8
Turn radio off
connect USB cable to computer and radio
do not push menu or power.
Click "Updates" on EZ Scan software
Click on "Check for DSP Firmware Update"
The scanner should do what it needs to do to complete the update on its own.
Ken
  #60 (permalink)
Old 12-24-2016, 10:43 PM
bravo14's Avatar
Turn radio off
It has been years I done this to the radio. I'm updating my files see what I get on dmr
