  #101 (permalink)
Old 01-02-2017, 7:34 PM
Please, I have both the PRO-18 and he PSR 800. I would be most appreciative if someone would e-mail me the 3.8 fw file.
Jim
  #102 (permalink)
Old 01-02-2017, 7:47 PM
Homeboys-Scanna's Avatar
Is there anything wrong with just posting the 3.8 file online and posting the link here in this forum? Or is there some reason it has to be like a little secret?
"Copy, 132 and Bush, cover's code 3."
  #103 (permalink)
Old 01-02-2017, 7:52 PM
Tried that, it keeps getting taken down due to copyright.
  #104 (permalink)
Old 01-02-2017, 9:50 PM
I also would appreciate someone sending me the FW 3.8 file....Thanks
  #105 (permalink)
Old 01-03-2017, 12:11 AM
Im looking for 3.8fw too.
  #106 (permalink)
Old 01-03-2017, 1:32 AM
Looking for PSR800 fw 3.8 also. Please and thank you.
Mudary
  #107 (permalink)
Old 01-03-2017, 1:00 PM
Garymaxon1234's Avatar
Got the 3.8 file, thanks everybody that helped. Works great on my local connect Plus system. One problem I had heard, if Restricted Access to System (RAS) is enabled on a Capacity Plus system, Whistler DMR will not decode seems to be true.
  #108 (permalink)
Old 01-03-2017, 1:09 PM
I also would appreciate a copy of ver 3.8
  #109 (permalink)
Old 01-04-2017, 9:15 PM
milcom_chaser's Avatar
Would be curious to know what DSP, ADC, and DAC settings you are all using/having success with post upgrade.
Thanks.
  #110 (permalink)
Old 01-04-2017, 11:57 PM
Thanks to all that replied...Got the 3.8 file!
  #111 (permalink)
Old 01-06-2017, 5:21 PM
stationmaster's Avatar
Default The 3.8 Bin file
Can someone kindly send along the 3.8 bin for me, I am aching to try this out....
  #112 (permalink)
Old 01-07-2017, 8:53 AM
Default 3.8 bin file
Could someone send me a copy too. Thanks
  #113 (permalink)
Old 01-07-2017, 9:14 AM
Could someone please send me the 3.8 firmware. Thank you.
  #114 (permalink)
Old 01-07-2017, 9:43 AM
Gotta give it a try, could someone please send me the 3.8 firmware also.....Thank you.
  #115 (permalink)
Old 01-07-2017, 10:22 AM
I also need the CPU Version 3.8. Thanks
  #116 (permalink)
Old 01-07-2017, 10:58 PM
Hello,
The link in this message may not last long.
http://forums.radioreference.com/rad...ml#post2695113
73 Eric
  #117 (permalink)
Old 01-10-2017, 3:36 PM
dispatch's Avatar
I also need CPU Version 3.8... Many thanks in advance...
  #118 (permalink)
Old 01-10-2017, 10:04 PM
After extensive testing today, in MY case that while DMR works great with the WS1080 firmware into the GRE PSR-800, however for some reason made a P-25 VHF Motorola Trunked System also in the scanner more difficult to receive (there were NO programming changes in any way). Keeping in mind that it is a “border-line” weaker marginal system for me anyway, but I was only decoding about 1/2 of those signals (as verified on another scanner), where as before it was 100% copy before the DMR. It did NOT affect conventional P25 (non-trunking) signals in any way.
So after a huge “sigh” , I reverted back to the original U2.0 CPU firmware / U1.3 DSP firmware and all is well again.
Thank goodness it’s not difficult to go back. Eric’s excellent program allows for you to switch back the CPU (and the DSP is put back using the PSR-800 EZ-Scan interface after). Oh well it was fun playing with it anyway. Anyone have any idea's here ??
swman
  #119 (permalink)
Old 01-11-2017, 12:46 AM
I reverted mine back to see if P25-II would sound better, but didn't notice any improvement. Did'nt expect it to as the original firmware was P25/2 capable.
Did you note your DSP Level ADJ, DAC, ADC settings before you reverted back?
  #120 (permalink)
Old 01-11-2017, 3:43 PM
Default PSR-800-WS1080 Device not recognized
Hope I am posting in the right place.
Updated the prs800 cpu to the 1080
When I went to upgrade the DSP i got error message "device not recognized"
So I tried to revert back with the tool but can't connect.
I then downloaded the driver for the 1080 but not sure what folder to place it in.
Any help appreciated.
Jack
