Old 05-16-2017, 8:00 PM
AC2OY's Avatar
Default Bricked my 800 today but brought if back to life!
I got a laptop today. After I loaded in EZscan I put my scanner configuration into this computer but something became corrupted. I was able to reformat the micro sd card and rewrite in the scanners configuration from the other PC. To my suprise and joy it wasnt as hard as I thought it would be. Now my 800 is back and running fine. Now I know that if I corrupt the card again what to do.
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Uniden 536 HP Kenwood TS-2000 Comet 250-B Diamond D3000N
Old 05-17-2017, 5:49 AM
Glad you resuscitated your PSR-800. No need for cardiopulmonary resuscitation in this case.
Steve AA6IO - ARRL and W5YI VE
GMRS WQWE213
Old 05-17-2017, 8:07 PM
AC2OY's Avatar
Yes I was happy and lucky to have my configuration on my other computer.
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Old 05-18-2017, 5:52 PM
The card just stores your programed data, the RR library and recordings.....Not technically "bricked" when it goes bad. Bricking involves the firmware which is in the CPU and DSP Chips.
It is a good reminder to use the ARCHIVE function in the software and as you make changes make another archive. Also you can keep a spare micro sd card on hand already programmed.
Old 06-28-2017, 8:17 AM
AC2OY's Avatar
Thanks Wacky I'm going to have to remember to do that. What I did discover is that when I picked up the scanner and tried to drill down some stuff manually,the scanner says I have no database on the card. Is there a way I can recover that without loosing my configuration that's programmed in or will I have to start from square one?
Michael AC2OY
Kenwood TH-F6A
GRE PSR-800
Old 06-28-2017, 11:08 AM
Not sure, but I would archive what you have in ezscan then select to copy FROM scanner/card into ezscan. then I would update the library and data then copy both TO the scanner/card.
See if the database is in there then make another archive ( all archives labeled by date and time so it is easy to sort them)
