Old 10-27-2007, 08:21 AM
N9JIG's Avatar
Send a message via AIM to N9JIG Send a message via Yahoo to N9JIG
Default PSR-500 Discriminator
I bit the bullet and opened my PSR-500 and found the Discriminator. Being a GRE radio I took a wild guess and tried looking for a "TP-4" and sure enough, there it was on the main board an inch below the volume/squelch control.
I connected this to a CD-1 PL decoder and a data slicer and it worked as well as other radios for decoding PL, DPL, DTMF and 3600 baud trunked control channels.
To access this remove the four screws on the rear case after removing the battery and battery door. You may wish to use a pigtail type jack connection or try to mount a jack on the radio someplace.
Standard disclaimers: Your radio, your risk etc. This will probably void your warranty. Your mileage may vary. Void where prohibited or taxed and in Vermont. Winner responsible for taxes and fees.
I am a dyslexic insomniac Agnostic. I stay up at night wondering if there is a dog.
Old 10-27-2007, 04:52 PM
KD4YGG's Avatar
Talking
Rich
Congrats on the first voided warranty (Heh! Heh!)
Actually thanks for posting the information.
73's
KD4YGG
"Have A Nice Day"
Old 10-27-2007, 05:43 PM
DickH's Avatar
Originally Posted by KD4YGG
Rich
Didn't I read in one of these threads that a Discriminator Tap is a built in feature of the PSR500?
Dick H
http://dickh.zenfolio.com
Old 10-27-2007, 06:14 PM
WayneH's Avatar
Forums Manager
It only outputs the formatted data messages sent out by the trunking formats which the scanner understands. These would include APCO-25 Trunking ("Motorola 9600"), Motorola 3600, EDACS, and LTR.
So no MPT, PassPort (damn IP), ATCS, paging, etc that others find of interest besides the big name formats.
-Wayne
Fastest response: wayne_h at radioreference dot com
Please do not reply to my moderator activity. I do not follow those threads.
Old 10-27-2007, 10:11 PM
ScanManQSL's Avatar
Congrats on the first voided warranty (Heh! Heh!).
N9JIG, Thank you for taking a bite out of your warranty just to share the useful information with all of us on RR. My first thought when seeing this picture was I cant believe you opened up your brand new $500 scanner!!!
Thank You!
-Ben-
A Proud Radioreference Junkie Since June 2ØØ3
Certified LWX SKYWARN Spotter
"I am just running a few watts, oops there goes the circuit breaker."
Old 10-28-2007, 12:37 PM
mkewman's Avatar
Send a message via AIM to mkewman Send a message via Yahoo to mkewman
huzza! you've got some cajones on you brother!
the preceeding post in no way reflects the views of anyone except myself.
Old 10-29-2007, 02:07 PM
Are you saying he's got some "big boxes" (cajones)? Or you mean "cojones", big bull balls?
JETorres
Old 10-29-2007, 02:25 PM
KSJ745's Avatar
That's WILD! Soooo COOL too!
Happy Scanning!
Old 10-29-2007, 07:37 PM
What software will one be able to run with the PSR-500 Discriminator?
Old 10-29-2007, 08:07 PM
N9JIG's Avatar
There are a lot of programs that require or at least prefer discriminator audio. These include many variations of Trunker, Treport, Trunk88, as well as ATCS Monitor, and many other programs that decode a variety of digital signals.
Old 10-29-2007, 08:12 PM
Rich, are you going to do the tap?
Old 10-29-2007, 08:18 PM
mancow's Avatar
By the way,
I already cracked mine open for other reasons.
While I was in there I put a small piece of white plastic on th e tri color LED with some duble sided tape. It made the light usable in a dark environment without blinding you even on a lower setting. It seemed to make the colors more true too since they seemed to mix in the white plastic. The color is more even, sort of like a flourescent light.
Old 10-29-2007, 08:42 PM
N9JIG's Avatar
Probably not, at least not now. I have a pair of PRO83's that I have taps on for the few times I need a portable with discriminator audio. Better a $60 radio for this than a $500 one.
I do have most of my mobile/base radios tapped, I use them all the time with various decoders.
Old 02-27-2010, 02:51 PM
This is a really old post, but I found it using a Google search. If you're still around, I'm curious why you did that when you could use the data port and USB cable?
Will the GRE, Uniden, and RadioShack radios with data port work with UniTrunker?
A: With the GRE PSR-500 and PSR-600 as well as the Radio Shack Pro-106 and Pro-197 you do not need a discriminator tap; the program reads through a USB cable attached to the radios' PC/IF data port. UniTrunker has support for EDACS, Motorola and P25 systems with the GRE PSR500/600, RadioShack Pro-106/197, and Uniden
Old 02-27-2010, 04:16 PM
N9JIG's Avatar
That's great if you are running applications that support that data format. I often need straight discriminator audio for things like data decoders (ATCS, trunked, etc.) or specialized PL/DPL decoders.
Since all my tapped radios are set up the same way, it is real convenient for me to do it this way.
Old 02-27-2010, 07:08 PM
I see. Thanks!
