Old 02-02-2008, 02:07 PM
Default Squelch Noise on CONV analog freqs
Hello,
I have noticed that when the mic is released on a tx'ing radio using an analog, conv repeater freq, there is squelch noise for second before the freq is silent... With my previous (analog) scanners, I would simply adjust the squelch dial to remedy this... I have tried fully opening and closing the squelch dial on my PSR-500, but this has no effect on the trailing squelch noise (static) on my unit...
The only "default" setting I adjusted was lowering the "digital detect timeout" per a suggestion in this forum, but I don't see how that could be affecting analog squelch settings... I have not yet messed around with the CTCSS/DCS settings...
Has anyone else experienced this and how was it remedied?
Old 02-02-2008, 11:39 PM
thewenk's Avatar
I have changed the RF SQ Fade from 10 to 3. I also have the HD2(End Detect) Qualify set at 45 instead of 75. My analog squelch tail is much shorter than it was before. I made these adjustments right after I got my PSR500 and as I remember, adjusting the RF SQ Fade had the biggest affect.
Dave
Old 02-03-2008, 01:21 PM
Thanks... I will give both a try...
Similar Threads
ne more freqs for opp analog in easterin ontario that are active ?? brockvegas Eastern Canada Radio Discussion Forum 5 08-26-2005 07:59 PM
Philly Analog Freqs Lancer252 Pennsylvania Radio Discussion Forum 8 10-09-2004 06:35 PM
Bucks County Analog Freqs ff12003 Pennsylvania Radio Discussion Forum 0 07-20-2004 11:14 AM
nationwide analog 800 and 900 mhz freqs... madscientist20042001 General Scanning Forum 2 06-19-2004 10:38 PM
800 and 900 mhz. analog freqs... madscientist20042001 Michigan Radio Discussion Forum 1 06-18-2004 11:32 PM
