Originally Posted by jonboy11
Thanks for your help. Your idea of checking the control channel got me to thinking. I went to my radioshack pro 2055 and found the cntrl channel for the same frequencies I have entered in the psr 500. Comparing the 2 I found that the control channel was not included in the download from radio refrence .com. I just entered the control channel from the rs scanner into the psr 500. Works!
I'm glad you have it worked out. I am guessing that when you imported the info from the RRDB you told it to do CC-ONLY - and thus it only imported the ones in Red in the RRDB.
855.71250 856.26250 856.93750* 857.26250 858.26250 859.26250 860.26250* 860.98750*
Was it one of those frequencies? If so, it likely isn't one of the ones with a * next to it (which would be Red in RRDB).
If you would, please do me a favor and go here -
http://www.radioreference.com/apps/submit/?sid=2093
Submit the frequency that is a control channel but which isn't listed as one. Then when the DB admins have time they'll make the update.
