I am new to the PSR-500, and I have a question...
I am using the ARC500 program. I have programmed in the Illinois StarCom21 system (http://www.radioreference.com/apps/db/?sid=2324) using the RadioReference import. The issue I have is that when the PSR-500 stops on a channel in this system, it stays for about 1-2 seconds, and then starts scanning again. The audio is clear, and the transmission sounds fine, but it just starts scanning again before the transmission is done. I don't know if there's a setting that is causing this or why it is happening. I don't know if it matters, but I have two priority CONV channels set up.
Thank you.
Thank you.
