Hi all,
I have recently returned to the scanning hobby after more than ten years. A lot has changed! I spend a lot of time in Riverside County (specifically Indo/Palm Desert/La Quita areas) and I'm very interested in monitoring LE comms. I have perused the RR database but am having some difficulties picking up comms. I would greatly appreciate any tips to help me with programming my RS PRO 2055.
I gather RSO is opertating an Analog EDACS (which I'm clueless about) system. I have set site freqs in order (ie LCN 1,2,3... Ch 0,1,2... respectively) for the Desert and Central sites in Bank 0 Ch 00-xx. I have also plugged in the Dec TGIDs in my 2055's Bank 0-1.
The symptoms... pretty much no comms. Although when scanning (up) I can see the EDACS TGID's pop up sporadically on the LCD but only momentarily and no voice. If I switch and manually cycle through I do pick up some LE comms which I can't identify (no EDACS TGIDs come up). I'm able to rec conv and such.
I'm wondering if anyone can verify RSO is indeed still on Analog EDACS?? Also, I'm hoping some of you may have some advice/tips to steer me in the right direction to get tuned in. Thanks!
