tach18k
- Joined
- Feb 8, 2005
- Messages
- 14
I'm just not getting this. I'm trying to get ICIS Verdugo running on my Arc 500/PSR-500. I use the data from RR. Nothing really works right. I do get the timely dead air / no audio on Red 1 UHF at the same time Red 1 is broadcasting VHF. Then there are times I get Red 1 working on UHF. But thats all I hear. I really dont hear everything, very little, maybe a dispatch or two. I seem to get more out of Verdugo on the old VHF than the new system (BCT15 unit.) I hear more on the old system. I never hear vhf and the uhf system at the same time with 2 different scanners. I have the same issue with the PD side of ICIS. Not much of anything. I get maybe a glimmer from a PD dispatch from the P25 side. One station is about all. Now I'm monitoring on top of the hills above, La Canada, Glendale, Pasadena, Burbank. So I'm right in the middle of everything, using a 18" 1/4 wave whip. I'm using all 33 possible freq' that are listed, on all sites. I use 380 as the offset. I have set up my scanner with every possible senerio of configuration I can. The two setups that do work is for the little I get is; Verdugo on MOT type 2 uhf. And the lone PD running MOT P25. I have listen to Verdugo in the past and heard everything all the time before the switch, so I know there is more traffic than what I'm hearing.
