I frequent the L.A. area and monitor areas I am passing through or visiting. I typically use a PRO-97 (now a PSR-300) and only monitor analog stuff (for now). When it comes to ICIS, I expect for the scanner to lock on to the strongest control channel (or I manually lock out the weak control channels). So I have programmed ICIS in a single bank with the desired talkgroups.
It appears, that because of the different band plans used by different sites, that I must program some sites into different banks. For example; Glendale, Burbank & Hauser Peak could be in the same bank (because they use the same band plan). But Pomona & Beverly Hills specifically would need their own banks.
Is there a way around this? In other words can I program two sites in the same bank with different band plans (such as Glendale & Oat Mtn) and have it work correctly? I thought I'd ask to make sure there are not some tricks out there. It seems crazy to have to use so many banks just to monitor various sites of the same system.
