Does anyone monitor LA Impact? Is it worth programming it in my scanner?
J judas12 Member Joined Apr 2, 2009 Messages 229 Location Los Angeles County, CA Aug 30, 2009 #1 Does anyone monitor LA Impact? Is it worth programming it in my scanner?
brandon Member Database Admin Joined Dec 19, 2002 Messages 3,511 Location SoCal Aug 30, 2009 #2 If your into surveillance type ops, then yes I would program it. Keep in mind much of it's simplex, so you need a good antenna to hear everyone. The air units are easy to pick up though.
K karldotcom Member Joined Apr 21, 2003 Messages 1,850 Location Burbank, CA Aug 30, 2009 #3 They have ICIS radios also...and the talkgroups are encrypted.
brandon Member Database Admin Joined Dec 19, 2002 Messages 3,511 Location SoCal Aug 30, 2009 #4 Thanks for the ICIS update.
