I believe that based on experiences over the last several years, they are actually trying to get away from patching altogether for major or potentially major wildland fires.
It becomes difficult to get everyone moved to VHF later in an incident when everyone is busy working and you are maybe not comfortable with your VHF equipment or whatever and the radio you use everyday works fine because it's patched.
You can't fault anyone in that situation, but it's tough when the "lowest common denominator" in the state is VHF. Even if you are patched to the VHF command channel and you need to get ahold of air attack or a helicopter for a drop and they are monitoring CDF Air to Ground, that Motorola isn't going to be much use. I'm not knocking OCFA at all, It's just the reality of the situation.
