In the absence of someone having a specific answer for you, I think there are only a certain number of potential VRS (Vehicular Repeater System) 700 MHz frequencies it could be. There's a much more specific thread from when Sacramento started using them, but you can see an example of how they're set up for Valley Division on the CHP page in the database. Then just scan the pool of VRS frequencies (from earlier threads in this forum) and find which freq/NAC matches for the Turquoise (Fort Tejon/Buttonwillow) in Central Division. Also keep in mind that the 700 MHz VRS radio channels replace the VHF mobile extender on 154.905 MHz.
Here is the thread for the Sacramento area VRS frquencies, including links to frequency lists, at least for Valley Division.
http://forums.radioreference.com/sa...cussion/190002-700mhz-p25-sacramento-chp.html
The way every division is now getting different frequencies for same-named (color) channels, it's anybody's guess whether the VRS frequencies will differ by division too. In that thread there is even speculation about the use of different VRS frequencies within a color, e.g. different VRS's for Valley Green for Grass Valley units vs for other Green offices' units.
As a matter of personal interest, do many people here routinely monitor the extenders? Or is most of the searching simply for the satisfaction that comes from finding and documenting new and unknown frequency usage? I haven't ever found them of much use, except or the questionably effective and always intermittent ability to know whether you're within range of a CHP unit. And what is the power output of the 700 extenders vis à vie the 154.905's? At least there shouldn't be much ducting on 700, much less any skip!
