South Bay Cities Communications Map
inigo88
California DB Admin
San Diego, CA
Hey guys,
I went to visit my girlfriend near Lawndale and Manhattan Beach yesterday. I didn't know the area at all, and was curious about the jurisdictional boundaries. You can drive five minutes in that area and go between several PD channels in South Bay Regional Public Communications Authority, to Redondo Beach PD, to Torrance PD. It turned out to be none of the above, and was actually an unincorporated area patrolled by LASD South LA station on Dispatch 12.
To try and understand the area better I made a map using this map as a base and this map to identify unincorporated areas, plus all the LASD station websites to fill in the blanks. It's color coded by which law enforcement agency patrols the area. Contract cities and unincorporated areas patrolled by LASD are outlined in bright red (hard to see sorry) and color coded based on dispatch channel. LASD stations aren't included because the point of the map is simply to have a quick reference for scanner programming of what departments cover what areas.
The quality isn't great since I had to make it in MS Paint (shudder) and I'm sure there are a few errors, but I wanted to share it none the less. Hopefully you will find it to be a useful reference, because it can sometimes be difficult to locate which freqs to program from the DB alone (especially some of the LASD areas). (The original author of the base map deserves all the credit, I didn't have to do very much.)
LAflyer
Global DB Admin
Moderator
SoCal
LA County has 88 independent cities, plus a few dozen unincorporated communities which can indeed be a bit confusing until you get to know the area well.
One easy trick is to look at street signs. Most cities have different types/colors. For example in City of LA they are on a blue background, with older signs being dark blue, and newer ones a lighter shade. Many cities also have small logos on streets signs which helps.
btw - if you are going to be in Lawndale much, try figuring out the PL for their public works dept. Freq is 158.775 but about 3 other relatively close cities are also users on it. Seems life is slow in Lawndale and no one has been able to confirm it for the Db.
SCPD
QRT
Virginia
I like what you have done. I'm going to try to either make pen/ink notations or type the frequencies on the map as well. I'm not down that way very often but when I get the chance to listen from my mother's house in Westchester (which I'm getting ready for sale) to the LASD and other South Bay cities I do.
inigo88
California DB Admin
San Diego, CA
Counter-clockwise from the upper left:
Santa Monica PD - 471.0625 (E09 NAC) (Encrypted)
Culver City PD - ICIS Trunking System - Culver City Access 484.25 (123.0 PL)
LASD Dispatch 12 - Marina Del Rey, South LA, Lawndale - 483.4375
Inglewood PD - 460.15 (192.8 PL)
SBRCC El Segundo PD - 471.3375 (85.4 PL)
SBRCC Ch 2 Hawthorne PD - 470.3875 (203.5 PL)
SBRCC Ch 3 Gardena PD - 470.8125 (203.5 PL)
SBRCC Ch 1 Manhattan/Hermosa Beach PD - 470.6375 (203.5 PL)
Redondo Beach PD - 460.075 (71.9 PL)
Torrance PD - 506.1625 (123.0 PL)
Palos Verdes Estates PD - 506.375 (205 DPL)
LASD Dispatch 7 - Lomita, Avalon - 484.0375
LASD L-Tac 2 - Lomita, Avalon, South LA, Marina Del Rey - 482.8875
LAPD Ch 5 - Harbor Dispatch - 484.2875 (466 NAC)
LAPD Ch 105 - Harbor Talkaround - 484.875 (466 NAC)
LAPD Ch 18 - Southeast Dispatch - 506.7875 (466 NAC)
LAPD Ch 118 - Southeast Talkaround - 506.725 (466 NAC)
LASD Dispatch 9 - Carson, Compton - 484.1625
LASD L-Tac 5 (Carson) - 483.4625
LASD L-Tac 13 (Compton) - 476.0625 (162.2 PL)
LASD Dispatch 4 - Century - 483.2625
LASD L-Tac 9 (Century) - 483.8625
Long Beach PD Ch 1 - South - 460.125 (141.3 PL)
Long Beach PD Ch 2 - East - 460.225 (141.3 PL)
Long Beach PD Ch 3 - North - 460.350 (141.3 PL)
Long Beach PD Ch 4 - West - 460.200 (141.3 PL)
Signal Hill PD - 800 MHz Motorola Type I Trunking System
LASD Dispatch 14 - Lakewood, Cerritos - 483.1375
LASD L-Tac 3 (Lakewood, Cerritos) - 483.3875
LASD Dispatch 13 - Norwalk, Pico Rivera - 483.7625
LASD L-Tac 10 (Norwalk, Pico Rivera) - 484.0125
Whittier/Santa Fe Springs PD - 470.3375 (162.2 PL)
Downey PD - 155.895 (156.7 PL)
South Gate PD - 155.67 (110.9 PL)
Bell Gardens PD - 453.925 (293 NAC)
Bell PD - 155.19 (107.2 PL)
Huntington Park PD - 155.79 (110.9 PL)
Vernon PD - 158.745 (179.9 PL)
Montebello PD - ICIS Trunking System
LASD Dispatch 3 - East LA, Commerce, Maywood, Cudahy - 483.2125
LASD L-Tac 6 (East LA, Commerce, Maywood, Cudahy) - 483.4875
The majority is UHF T-Band 470-512 Mhz, with a little bit of UHF 450-470 MHz and VHF as well.
