Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > California Radio Discussion Forum > Greater Los Angeles & Inland Areas Discussion
Greater Los Angeles & Inland Areas Discussion Local area specific discussion for Los Angeles and its outlying areas such as Ventura and Orange Counties, and the Inland Empire area.
Old 07-18-2013, 10:31 PM
Default Ventura County FD update
VCFD is in a long term term upgrade program, and the frequencies listed in the database are not correct for most of the channels as they are presently assigned. Here is a current list of the frequencies VCFD is using*:
155.0550 Dispatch
154.3250 Command 2
153.9500 Tactical 3
154.2950 Tac 4 VFire 23
153.8750 Command 5
154.0250 Tactical 6
154.2650 Tac 7 VFire 22
155.9850 Command 8
153.8300 Tactical 9
154.3025 Tac 10 VFire 26
154.2350 Air / Ground
154.2800 Calema VFire 21
154.0700 Oxnard 13 / 14
154.1450 Oxnard 15 / 16
* note - this is for "bank one" as their radios are currently programmed. The radios themselves can be programmed with up to 25 banks of 16 channels each, and other banks contain such channels as Cal Fire, adjacent agencies, LEAs, marine channels, etc. If there is desire, I can post those banks as well.
Matthew
Old 11-19-2013, 3:02 PM
post them all Matt
Old 11-21-2013, 12:57 AM
What portables are they using? I was under the assumption they were using the BK GPH/DPH Commanders with 20ch per group?
Old 11-21-2013, 12:38 PM
VCFD uses new Motorola APX, Calfire uses the Bendiz King GPH radios and Ventura City Uses the new KING P150s
Old 12-06-2013, 7:36 PM
BigEvil's Avatar
could you submit this for the database?
