Handhelds are issued for each shift and an officer will likely have a different handheld each day, even if they are assigned to the same patrol area day after day. They are likely to have a different car each day as well. They log in the handhelds to match the unit and officer ID in case an officer activates the emergency trigger feature. The handheld transmits the radio ID each time it is keyed. If the officer is unable to speak after triggering it the CAD will identify the officer and status.
Without the handheld being logged in none of this would be possible.
On another subject related to the handhelds, are they still called ROVERS? (Remote Out of Vehicle Emergency Radio System) This was a term that started when the LAPD changed to UHF from VHF around 1980 as I recall. They were a little behind many other agencies as far as equipping their officers with handhelds.
What is not known all that well is there are many more receive only sites than repeaters. The receivers are voted and feed the repeaters. The LAFD has the same type of system, something that is more critical with their 800 MHz system.
