Custom tables for P25 ICIS Burbank
Engine104
Member since 2005
Winnetka, CA
I've been able to program the P25 Pasadena ICIS system on my Pro-96 and it works ok but, back in the pre-P25 ICIS days, I always received the Burbank system better here in the west SFV.
These are my settings for Glendale: MOT 9600 custom table, Base freq= 470.00625, Offset = 4096, Step size = 6.25 KHz.
Does anyone have custom tables for the P25 Burbank system?
-KG6EJT
kma371
QRT
You shouldn't need tables for p25 systems as they are set automatically from control channel data.
Engine104
Member since 2005
Winnetka, CA
That is true, except I think on older scanners, like my Pro-96, you do have to manually set them.. After I downloaded the Pasadena ISIS system from the RR database into Win96, it would not work until I found an old forum post on here that gave the specs I mentioned in my previous post. I edited the bank settings in Win 96 and it worked fine. The only problem is back on the old system I used to receive the Glendale cell better than Pasadena. I am receiving the Pasadena cell ok, but I wanted to try to see if Glendale came in better from my home.
Anyway, that's why I wanted to see if anyone had found the custom table settings for the P25 Glendale ICIS cell.
Anderegg
Enter text in this field
San Diego
Uniden XT scanners will actually have blank tables until they decode the control channel for a little bit, then when you check them using the menu, they will auto-populate. Nifty...
Paul
Engine104
Member since 2005
Winnetka, CA
Paul
That is cool. I wish you were in L.A. and not SD so you could take a look at your XT and let me know what the tables, offset and base freq are showing for the Burbank P25 ICIS cell....
Aero125
Los Angeles, CA
The Burbank P25 ICI cell is not really needed if you have the Glendale P25 cell programmed. Glendale completely overlays Burbank's coverage and goes much further.
Engine104
Member since 2005
Winnetka, CA
I misspoke. Sorry. I meant to say the Pasadena P25 cell is in my Pro-96 and works ok, but I always received the Glendale cell better than Pasadena under the old system. I suspect that may still be the case with the P25 system, so I'd like to try that if I can find the custom table, base freq and offset for the Glendale cell.
talkpair
Clinton County, MO
If someone here could run Pro96Com on the Glendale site and post the generated Tower file I'd be glad to help.
Either that or send it in a PM to me.
mikkut
I'm a novice user of Pro96.com so bear with me ... here is a screen capture of what comes up on the Glendale site ...how do I generate a tower file?
Engine104
Member since 2005
Winnetka, CA
TalkPair sent me the tables below and it seems to be working. I edited my file in Win96 and it is working.
Radio Shack Pro96, Pro2096
Custom Table
Low High Base
Chan Chan Offset Frequency Step
0 4095 0 450.00625 6.25
4096 8191 4096 470.00625 6.25
8192 12287 8192 494.00625 6.25
kma371
QRT
Custom Table
Low High Base
if you are using those tables, it seems to be exactly what the control channel was putting out. so did you actually change anything?
Engine104
Member since 2005
Winnetka, CA
I had the control channel from RR.
Unlike the more modern radios, the Pro-96 does not automatically set the custom or extended tables from data from the control channel. That has to be inputted manually. I use Win96 for all programming and for doing that.
Paco-Jerte
You Member, Member!
34.0500° N, 118.2500° W
Hi,
I uploaded a screen shot of the bank and settings from my Win96 file. It's in my public album in my rofile on here. Let me know if you can't get to it.
-Larry
Thanks worked great and U asked me what Antenna I am using with the 96, its the RS Telescopic one I bought for $2.00 when Topanga Mall store was closing. Also using the RS 800MHz one that also purchased from there for $3.50.
