Copy this to Notepad and then save as 440_10 with an SC4 extension (440_10.SC4).
Code:
// Orion 450-520 MHz to 440-510 MHz for 70 centimeter use.
// Program 455.000 MHz to get 445.000 MHz
// MOVES BASE FREQ TO 440 MHZ ((WAS 450 MHZ))
FREQTBL /f /b0 /=1A
FREQTBL /f /b1 /=39
FREQTBL /f /b2 /=DE
FREQTBL /f /b3 /=00
FREQTBL /f /b4 /=1A
FREQTBL /f /b5 /=39
FREQTBL /f /b6 /=DE
FREQTBL /f /b7 /=00
FREQTBL /f /b8 /=1A
FREQTBL /f /b9 /=39
FREQTBL /f /bA /=DE
FREQTBL /f /bB /=00
I just put this together rather quickly. I sent it as a PM last night, because I wasn't sure if would work on the M7100 as it was originally an Orion SC4, but since rfradioconsult said any SC4 will work, then it should.
To change the band, you change the HEX digits after the '=', i.e., 1A, 39, DE, and 00. Notice those 4 groups repeat three times. You put those 4 groups into the Windows calculator using the HEX button and then click the DEC button. So 1A39DE00 in HEX becomes 440000000 (440 MHz) in DEC. So if you want to create a new SC4 for lowband to add 6 meters, you change the 1A39DE00 to 025317C0, which translates to 39000000 (39 MHz) Now when you put in 48.525 into Programmer, when the radio is programmed, the software & SC4 file change the frequency to 52.525 (Out of band for the original radio).
You have to remember to SAVE the original as once you read the radio again, the real channels will appear, i.e., 52.525. So if you try to read a radio written with an SC4 for out of band operation and then try to write back to the radio (even if you didn't change anything), the write will fail because of the out of band frequencies. So if you want to make changes, it's easiest to save a copy of the original file and edit it. Otherwise you'll be doing a lot of calculations to every single frequency in the radio, not just the out of band frequencies.
The info data after the // is for identification purposes only. I usually change it so I can always tel what the file is suppose to do, even if the name of the SC4 got messed up.
Have fun!
