Remember that the data rate, parity and stop bits are set in the data screen in Programmer/RPM - by default it's 9600 baud and even parity, so you won't see anything if you're set up wrong, and very little uses even parity any more.
The data connection (in EDACS anyway) uses the RDI protocol, so you won't get anything really meaningful out of it. However, there are some diagnostics (I think) buried in there - you might try sending <ctrl>D (ascii 4) followed by 3 and 1 to get some stats, or <ctrl>D 8 for system stats.
Hope that helps,
Enid.
