Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 06-06-2009, 10:45 AM
Default P7100 Encryption Problem
We currently have MPA select radios with DES encryption and we are trying to incorporate P7150 scan radios. Since they come with AES encryption capabilities, M/A Com gave me these codes to make them work with what we have: J2R15E05.biz and F6R06K02.dsp. I put these on the radios, loaded the DES key in the Key Admin software, but when I try to load the key it says "The Distribution Set could not be loaded. The following error was reported: Key Loading failed. Unable to read a valid response. Resolve the error and click Load to try again." Does anyone know how to "resolve the error"? Thanks for the help!
Old 06-06-2009, 11:39 PM
LID109's Avatar
in the p71, are your systems set to "Aegis" per system?
Per system, are you selected on Key 1?
in conventional or trunked group sets is you digital voice mode set to "key 1" per channel?
Old 06-08-2009, 08:54 AM
You have a Direct FM radio. The keyloader only works with the I&Q radios. You must purchase the Key Manager software package and keyload cable which looks like the ribless programming cable. Cost? around ten grand.
Old 06-08-2009, 08:55 AM
The error you're seeing suggests that the keyloader couldn't talk to the radio. So...does the radio show KEYLOAD on the display? Does it do anything when you try to load the set? Are you using a keyload cable (and not one of the other ones like a data cable or a programming cable)?
Sounds like there's a call to TAC in your future
Old 06-08-2009, 12:35 PM
I'm sorry, I didn't read properly the first time (monday morning). Do you have a keycard and card reader? The key manager is used to create the keys and write them to the keycards of which you should have at least two, the master and the distribution. Once the keys are loaded onto the keycard, which is also password protected, you need to close the key manager software and open the keyloader program which reads and validates the keys from the distribution keycard and then loads it into the radio.
As far as loading it into the radio goes its pretty straight forward. Connect the cable onto the radio and it goes to keyload mode automatically. The software does all the necessary handshaking.
Old 06-08-2009, 12:52 PM
WCRadioGuy's Avatar
Check your PM. If I read you correctly, this is military.
Similar Threads
Encryption being used: Can you still use your scanner? altec General Scanning Forum 26 04-17-2009 03:47 PM
Win96 and Vista scannsw Scanner Programming Software 24 05-24-2008 09:02 AM
Encryption on SAFE-T? kevinratcliff Indiana Radio Discussion Forum 51 04-02-2008 10:23 AM
Weird EDACS scanning problem c0wb0yup Alabama Radio Discussion Forum 1 02-20-2006 09:57 AM
BC898T TV CH 8 Problem N9WP Uniden Scanners 4 11-30-2004 08:05 AM
