Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 07-08-2009, 04:11 PM
Default LPE-200 Backup Question -- Important Files to Save..
Just curious on the important files you would recommend saving on a new (used-new) LPE-200? Reading through the threads, I found information from the LPE-gurus stating these are the important files to save in case of such emergency and recovery is required:
*.TRK / *.ENC / *.BIZ & *.BIS / *.DSP & *.ADI
ProGrammer automatically saves the TRK & ENC and I figured out how to save the DSP/ADI with Radio Maintenance and writing it to a file. I cannot figure out the saving of the "BIZ or BIS" or where I would read this info.
--ProGrammer v1.8, LPE-200.
I just want to be certain I have all the most important files saved, and what would be required for a successful restore if the need shall arise. Perhaps someone could review the steps for saving these important files, and if you have the time maybe explain (briefly) what each file contains in information.
Thanks so much for your help and knowledge..
Old 07-08-2009, 05:51 PM
the BIZ files are compressed versions of the BIN and DSP files. They're not in the radio as such, they're just used as distribution & archiving files and will only live on your PC hard disc.
ADI files relate to MRK and Orion only, so you don't need these for LPE200 - but if you have a MRK or Orion, simply replace DSP below with ADI. If your MRK or Orion doesn't have an ADI file, thats fine... but if it does, back it up along with everything else. A LPE200 will always have a DSP file.
I think the important files to backup are:
*.BIN (the flash, or 'operating system' of your LPE)
*.DSP (the DSP software files, necessary for any LPE wether or not it has digital voice options)
*.ENC (located in your 'backup' directory - this is the feature encryption string)
*.TRK (also located in your 'backup' directory - this is your tracking data)
*.TRS (located in your 'Sets' directory - the individual trunked system set files)
*.CVS (also located in your 'Sets' directory - these are the conventional frequency set files)
and finally
*.PER file (in the Pers directory, this is the overall personallity file that references to the *.TRS and *.CVS files above to create the whole picture)
I would also do the following:
Read your feature encryption string using RadioMaint, cut & paste to a text document. Read your tracking data using RadioMaint, cut & paste to a text document. In the Features menu of the radio, get the Serial ROM # and also record the options installed, CNVCHN#, SYSGRP# and TRKSYS# (just for interests sake). Also make note of the radio serial number on the back chassis underneath the battery (something like UA30009ABC or 0009ABC). Put all that in a text file and keep it with the other files. It doubles up on recording some information, but I sometimes find it handy to refer to without loading up RadioMaint or ProGrammer.
And one more thing that I thought of, though I'm not sure if they'll be saved when you read the config from the radio: *.SC4 files. These add in minor functionality to ProGrammer and as a result will affect the config written to the radio. But if you then read that config into a different PC, I don't think the SC4 file is recreated.
Old 07-08-2009, 10:03 PM
Thanks so much.. so perfectly understandable and thorough.
Your information and help is greatly appreciated.
Similar Threads
Ma/Com LPE 200 Charger FireMan16 Old Classifieds Archives 2 01-14-2007 03:55 PM
programming system in LPE 200 scanamateur Harris / MA/COM / GE / Ericsson Forum 2 01-10-2007 12:26 AM
My Arc396 Backup Directory is Humongous! ILikeHatchChili Scanner Programming Software 1 12-03-2005 09:14 AM
Newbie Question: RS Pro-95 Win95 Files Help ClutchKargo Radio Shack Scanners 8 01-30-2005 06:42 PM
SSD's files and a Fleetnet question EJB Eastern Canada Radio Discussion Forum 2 07-05-2004 04:24 AM
