Here's the whole ball of wax.
P7100IP EDACS / P25 Trunked Portable feature encryption upgrades, kit numbers and prices
YRPL3Y Status/Message $105.00
YRPL1X ProRoaming (includes ProScanTM and Priority System Scan) $305.00
YRPL1Y Priority System Scan $105.00
YRPL5K ProfileTM Over-the-Air Programming $305.00
YRPL3X EDACS Mobile data $205.00
YRPL3R 800 System/Groups $205.00
YRPLEN Extended Networks (800 Sys/Grp, ProRoaming, ProFile) $555.00
YRPLCC Critical Communications (Emergency, Dynamic Rgp) $205.00
YRPL7G EDACS Security Key (ESK) / P25 Personality Lock $105.00
YRL2VA AEGIS Unencrypted $250.00
YRL2VE **** AEGIS VGE $800.00
YRL2VS AEGIS DES $955.00
YRL2AV **** AEGIS Unencrypted to AEGIS VGE $550.00
YRL2AS AEGIS Unencrypted to AEGIS DES $705.00
YR3U3V **** AEGIS VGE to AEGIS DES $155.00
YRHAMB P7100IP ProVoice Unencrypted $705.00
YRHAMS P7100IP ProVoice DES $1210.00
YRL2BS P7100IP ProVoice Unencrypted to ProVoice DES $505.00
YRPLCA Project 25 CAI (P25 Conventional, Unencrypted Digital Voice) $350.00
MAYR-NP7AT **** EDACS Analog to Project 25 Trunked ( Unencrypted Digital Voice) $1305.00
MAYR-NPL7B **** EDACS ProVoice to Project 25 Trunked ( Unencrypted Digital Voice) $600.00
YRHACS Project 25 DES $1350.00
YRCACS Project 25 Unencrypted to Project 25 DES $500.00
YRPL7M Project 25 AES $1700.00
YRCA7M Project 25 Unencrypted to Project 25 AES $850.00
YRCS7M Project 25 DES to Project 25 AES $350.00
YRPL5L Project 25 Over-The-Air ReKeying (P25 OTAR) $650.00
MAYR-NPL7J FIPS 140-2 $305.00
YRPL7K ** Direct Frequency Entry $105.00
YRPL7N *** Radio TextLink $105.00
** NOTE: Option YRPL7K allows for Direct Frequency Entry of one channel only (only on System control heads with DTMF keypad). This feature is only available to select customers as mandated per FCC 47 CFR 90.203(e) and 47 CFR 90.427(b).
*** NOTE: Option YRPL7N (Radio TextLink) also includes Option YRPL3R (Status/Message) but needs to be ordered with Option YRPL3X (EDACS Mobile data) to enable Radio TextLink feature.
**** NOTE: Options YRL2VE, YRL2AV, YR3U3V, MAYR-NP7AT,and MAYR-NPL7B only apply to "Direct FM" P7100 radios using "F" series DSP codes.
P7100IP Conventional / P25 Conventional Portable
MAYR-NP7CE EDACS Analog $1095.00
MAYR-NPL7S **** Project 25 Trunked ( Unencrypted Digital Voice) $1795.00
YRPL7G P25 Personality Lock $105.00
**** NOTE: Options YRL2VE, YRL2AV, YR3U3V, and MAYR-NPL7S only applies to "Direct FM" P7100 radios using "F" series DSP codes.
