Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 07-16-2009, 09:23 AM
10-95's Avatar
Default 7100ip digverr err
I have a VHF 7100IP I picked up on Ebay. The radio looks new and when read
with programmer I am able to go in and setup P25 conventional channels, which I have never been able to do unless the radio had that specific option. When I program the radio, the P25 channel has a "25" displayed in the bottom of the display, when the radio receives an analog transmission on that channel it switches to "A" for analog I guess.
My problem is when I attempt to transmit, the display shows DIGVER ERR.
Here are the DSP/ADI files in the radio:
J2R10A05
F4RO6E05
When I go into the FCC TEST MENU I am able to get the radio to transmit on selected channel in P25 mode, it even transmits my radio ID to my XTS, but it will only do that in test mode. Anyone have any idea if I need a new combination of ADI/DSP files to get the radio running correctly in P25 mode??
Thanks for any help
C:\mrss\depot\labtool.exe
C:\outrage.exe
/\/\ XTS-5000 VHF FPP
/\/\ Spectra VHF
/\/\ XTS-5000 UHF
/\/\ Astro Saber II
Uniden BCD396T
"Go digital or go home!"
Old 07-16-2009, 09:39 AM
Sounds like it doesn't have the features for P25...
Old 07-16-2009, 09:47 AM
10-95's Avatar
I thought maybe that was it. I beleive this radio may have been an engineering radio or test radio of some sort . Usually when I've owned radios without the P25 option I am unable to even do anything in programmer in the P25 windows, however on this one I am.
Like I said, in FCC TEST MENU it sends P25 fine and my xts displays the radio's ID.
Not sure if a different ADI/DSP file would help clear up the problem. The radio looks new and still has the plastic on the display. The thing works great in analog, but I'd love to have the P25 to use as well.
C:\outrage.exe
/\/\ Spectra VHF
/\/\ XTS-5000 UHF
/\/\ Astro Saber II
Uniden BCD396T
Old 07-16-2009, 12:40 PM
10-95's Avatar
Well, I've been told I need F8????? radio code for the radio to function P25 unencrypted.
Anyone have a copy of the code?
C:\outrage.exe
/\/\ Spectra VHF
/\/\ XTS-5000 UHF
/\/\ Astro Saber II
Uniden BCD396T
Old 07-16-2009, 06:29 PM
To operate in P25 CAI (NON-TRUNKING) mode, F4 or F6 class codes will work. (Non-encrypted and DES supporting, respectively)
You'd only need F8 code for P25 trunking, option 39.
ProGrammer will allow you to create data for a P25 conventional system even if your radio doesn't have the feature. Load up the file to the radio and you'll just get errors.
ProGrammer doesn't know or care what features are in your specific radio. It does make some adjustments based on what type of radio you select in ProGrammer, but within a given radio type,
it allows programming of any type of data that doesn't require specific authorization like ESK data.
The radio is where the "Yes you can use this feature, no you can't use that one" logic resides, based
on the features that are enabled.
Elroy
Old 07-22-2009, 02:58 PM
HarrisRF's Avatar
I once had a radio with no features. I was still able to add one TG to an EDACS system and use it, even though i was not featured to be EDACS. maybe this falls into that category?
Similar Threads
FS: Real P25 trunking M/A-Com 7100IP ElroyJetson Old Classifieds Archives 0 08-17-2008 11:00 PM
Feat Err 0552 & reflashing etc. mitaux8030 Harris / MA/COM / GE / Ericsson Forum 3 07-02-2008 08:39 PM
FS: New front covers for M/A-Com 5100IP radios. (also fits 7100IP) ElroyJetson Old Classifieds Archives 0 02-10-2008 10:25 PM
7100IP DSP and flash codes ElroyJetson Harris / MA/COM / GE / Ericsson Forum 1 10-04-2007 12:11 AM
M/A-Com 7100IP system model portable, provoice, FS. Package. ElroyJetson Old Classifieds Archives 0 08-19-2007 02:23 AM
