Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 07-23-2009, 03:42 PM
Default EDACS Provoice trunking with a conventional radio
Hi all! Our local EDACS system uses ESK so its not possible to put the radio on its control channels even in rx only mode,
is it possible to listen Provoice traffic in EDACS system by programming EDACS traffic channels as a conventional Provoice channels and scanning them all, like motorolas may do with astro9600 trunking?
Old 07-23-2009, 10:43 PM
Send a message via Yahoo to Radioman96p71
Not sure if that would work or not. I Have tried it with AEGIS and it did not work. Wouldn't sync up correctly it seems. Would get little pops and clicks on the audio sometimes. Usually it would just allow the raw audio thru, i.e. you could hear the analog channel data sound like it wasnt recognizing the 'noise' as AEGIS data. Whether or not it would work for ProVoice i have no idea. I'll give it a shot tonight see if i can catch some.
KCØGIK
Old 07-24-2009, 03:07 AM
The solution is simple - in the digital voice options, select data polarity 'inverted'. Seems the digital voice data goes through a 180 degree phase reversal when transmitted by the base station.
Old 07-24-2009, 11:15 AM
Wow, all this time and I never noticed that in ProGrammer! Learn something new every day, I'll give that a shot. FYI, without setting the invert in ProGrammer as mitaux8030 suggested, ProVoice behaves the same as AEGIS, no decoded audio. I'll flip it to inverted and see what that does!
KCØGIK
Old 07-24-2009, 04:16 PM
Yes - you also have to set the outside address to 51 (decimal) rather than the 85 that it has by default.
Old 07-24-2009, 05:13 PM
All good information, thanks a bunch guys! Have to add that to the pile of knowledge i may need someday!!
KCØGIK
Old 07-24-2009, 11:38 PM
I'm making a note of this, myself.
I use essentially the same trick to monitor a Motorola Astro digital system with conventional (digital) scan with an Astro Saber. It works very well. And the system is not very busy so I usually catch both sides
of any given conversation, as well as if it were actually following the trunking system in trunking mode.
Now for my next trick, I guess eventually I'll have to see if I can use a M/A-Com radio to monitor a
Motorola digital trunked system in the same manner, or use a Motorola radio with a M/A-Com system in the same way. (But obviously, in P25 mode, not ProVoice.)
Elroy
Old 07-24-2009, 11:59 PM
blantonl's Avatar
Administrator
Set the RX Address to 172, and as previously indicated ProVoice on EDACS Trunking is inverted.
Lindsay C. Blanton III
President - RadioReference.com LLC
Facebook: RadioReference | Twitter: @RadioReference
Old 07-25-2009, 12:27 AM
Michael-SATX's Avatar
Lindsay, what make/model of radio are you refering to ? Does this thread relate to our Pro-Voice TRS?
OK, back to my Pro-106 which simply does the "ESK" ignore trick like your PSR-500 scanner does
Botom line, other than us here in San Antonio, having the 19 LCN's of the Blue Simulcast layer in one scanlist and the 19 LCN's of the Gold Simulcast layer in another scanlist and get to properly trunk track
just the Analog Talk Groups .... is this thread implying I can do more with a "conventional" scanner ?
Or do I need to bestow on myself another radio to decode Pro-Voice like an LPE-200 or other radio ?
So what in your estimation, what does it take to trunk track EDCAS Pro-Voice talk groups in SATX ?
Bring It )
Michael
Pro-106, 164, 96, 95, 92, 83, iCom-R3
Pro-2067, 2055, 2052, 2017, BC-350-A
Grundig YB-400PE, Radio Shack DX-396
RS 20-043, RS 20-176, RS 20-283's/HH's
Old 07-25-2009, 07:52 AM
Several radio vendors tested their P25 radios on a Motorola statewide P25 system for cross compatibility...I can't recall the State, but it was in the midwest...Illionis maybe?
Edit: Found a reference in Channels to such testing in Arizona. (Page 18)
http://www.macom-wireless.com/Channe...ls_v6_iss1.pdf
Old 07-29-2009, 11:29 AM
Understanding the above .. setting the RX and TX to 172 will allow you to listen to PV conventional transmissions. That is fine, but is there a way to listen to Radio to Radio PV transmissions ? If you scan the LCN's for a system for example you will always have the radio stop on the control channel, thus making the scan feature useless.
I understand that this is only capable on "supervisor" type radios. Can someone enlighten me on this capability.
Kevin
Scanning the Airwaves
Old 07-29-2009, 01:07 PM
davidbond21's Avatar
Send a message via ICQ to davidbond21
The RX/TX Address should be thought of as being the ProVoice equivalent of a P25 NAC. Setting the RX Address to 172 tells the radio to unsquelch on any ProVoice transmission, not just those containing a matching value.
Yes, scanning the LCN's conventionally will eventually land you on the control channel, but all you have to do is remove that offending channel from the scan list, one or two key presses at most. Unless your radio is set to have a fixed scan list, in which case it will have to be reprogrammed to allow the scan list to be user editable.
(+)-3-methoxy-17-methyl-(9α,13α,14α)-morphinan
BC350C, IC-R7000, PRO-95, PRO-96, PRO-197, PSR-500
FT-7800R, Racal 25's, LPE-200's, Jaguar 725M
Old 07-29-2009, 01:20 PM
"nuisance delete" is your friend in this case.
So is 172 the "listen to all ProVoice traffic" address?
Elroy
Old 07-29-2009, 02:02 PM
Elroy
I think that it is, and I believe that ProGrammer refers to this as the "All Call" value. That and since I've plugged this into my radio, it hasn't been quiet for more than about 15 seconds.
Old 07-30-2009, 06:06 PM
I know all freq and lcn of my local edacs/provoice system. What i need to program radio i trunking mode?
Similar Threads
Darwin Cove Convention Centre grant Australia Radio Discussion Forums 8 10-31-2008 05:51 AM
FS: Real P25 trunking M/A-Com 7100IP ElroyJetson Old Classifieds Archives 0 08-17-2008 11:00 PM
Okc Edacs mam1081 Oklahoma Radio Discussion Forum 29 11-28-2005 08:07 PM
Fairfax County Police Designators KI4IHC Virginia Radio Discussion Forum 3 08-13-2005 05:42 PM
The July 2005 So. NV Radio Scanner Book (3rd Ed.) TOUGHLIFE Nevada Radio Discussion Forum 13 07-13-2005 08:49 AM
