Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 07-28-2009, 05:14 AM
Default Hardware Err #0112 cured
Hi all,
Had a Prism portable recently that was exhibiting a peculiar problem... whenever a received signal went below a certain strength - either conventional or EDACS - the radio would issue a #0112 error and reboot.
The maint manual doesn't mention what it is, but the cure is to do a realignment of RSSI and mute settings - or a quick and dirty stuff-a-default-tracking-data-file in there.
Might be useful information for you to keep in the back of your mind.
Old 08-04-2009, 05:09 PM
A little more on this: the particular value that caused the problem was the wide band squelch value - it was set to 205, and a document that I have says that this value should always be a figure below 159 for correct operation.
Similar Threads
PSR-500 Hardware Versions DrDSP GRE Scanners 1 10-06-2008 08:42 AM
Hardware errors on P7100 portables...help diagnose the problem(s). ElroyJetson Harris / MA/COM / GE / Ericsson Forum 11 08-26-2008 10:10 AM
Feat Err 0552 & reflashing etc. mitaux8030 Harris / MA/COM / GE / Ericsson Forum 3 07-02-2008 08:39 PM
Deciphering Jaguar hardware error codes? ElroyJetson Harris / MA/COM / GE / Ericsson Forum 7 12-07-2007 12:11 AM
