Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 07-28-2009, 05:50 AM
Default HDT use
Is there some sort of 'guide' other than the very brief built-in help for HDT?
For example, CMD x has numerous actions, depending on the number you enter eg:
CMD 50 nnnnnnnnn sets a particular receive frequency when in test mode (CMD 0 does that)
CMD 2 spits out RSSI values ad nauseum
But I'm sure there's many more 'interesting' CMDs and other instructions...
Also, is there a way to use a 'RIB-less' cable on a MRK to access HDT? I presume its as simple as changing the UDC resistor value?
Old 07-28-2009, 09:48 AM
This is relevant to my interests. There is another thread on HDT, too.
Please list any and all commands that you've discovered, and what they do, if possible.
Elroy
Old 08-02-2009, 11:08 PM
From various Maint Manuals for the LPE200, I can see the following commands:
First, enter test mode by entering
cmd 0 radio responds by displaying TESTMODE (remembering all the below are from LPE200 documents only, so I don't know if they'll work on others)
cmd 2 = display RSSI values, live updating, on one line of your PC terminal program (press enter to quit)
cmd 2 0 = display the Weak RSSI value, as per above updates live on on line of PC terminal program, valid ranges from 35 to 100
cmd 2 1 = display the Strong RSSI value, as per above updates live on on line of PC terminal program, valid ranges from 139 to 204
cmd 30 = display tracking data
cmd 43 0 nn vv = alter tracking data values, where nn is the the field to change (numbering starts from field 0) and vv is the new value. This doesn't write the changes to E2PROM, only sets the changes. For example if you wanted to change the very first value of the tracking data as displayed (which happens to be a value for Tracking Version Number) you would enter cmd 43 0 0 x. To change the 33rd value (which happens to be the 'strong' -40dBm RSSI value) you would enter 43 0 32 x.
cmd 29 = write changes to tracking data made with above command.
cmd 71 aa bb cc = sets tracking data segment (I don't know how this differs to cmd 43 above)
where aa is the power level setting; 0=very low, 1=low, 2=high
where bb is the TX band; 0=normal, 1=talkaround
where cc is the freq band location; 0=low, 1=mid, 2=high
apparently for 800 MHz, some frequency examples break down as:
806 MHz is aa 0 0
815 MHz is aa 0 1
824 MHz is aa 0 2
851 MHz is aa 1 0
860 MHz is aa 1 1
869 MHz is aa 1 2
cmd 74 1 = turn on RF PA; cmd 74 0 = turn off RF PA
cmd 85 0 = sets PA power control loop into open loop mode
cmd 81 = display current power adjustment value for the specific band-split and band-segment selected (in cmd 71 above, I presume)
cmd 80 x = increase or decrease output power using same scale values as given in cmd 81 above.
cmd 82 1 = reads current power output level as a value that the radio power control loop is currently sensing, and places the value to the TX_PWR_SENSE location in tracking data. (again, cmd 29 needs to be issued to actually write this data)
cmd 9 = display current AFC value for master reference oscillator
cmd 9 x = alter AFC by one step, where x is 0 for decrement one step, 1 for increment by one step.
cmd 50 nnnnnnnnn = set RX frequency, where nnnnnnnnn is freq in MHz ie 815212500 is 815.2125 MHz
cmd 70 nnnnnnnnn = set TX frequency, where nnnnnnnnn is freq in MHz ie 815212500 is 815.2125 MHz
cmd 3 x = set radio to wide or narrowband operation, where x is 0 for wideband, 1 for narrowband
cmd 52 2 = check squelch status, if ?PASS 1 is given then squelch is open, if ?PASS 0 then squelch is closed.
cmd 52 1 vv = set squelch value where vv is 1 for tight (high RF threshold) and up to 159 for loose (low RF threshold). Settings above 159 are not recommended.
cmd 54 0 = unmute RX audio (and I presume cmd 54 1 mutes again)
I got these commands from the AE/LZB 119 1641/3 rev E and AE/LZB 119 3520/1 Rev 3 documents. No doubt there's plenty more commands. In fact, I wonder if programmer 'talks' in this cmd language to send just about everything it needs to: tracking data, feature encryption information, personality information, hardware version queries etc etc.
More than that, I wonder if this HDT language, and the cmd's are 'universal' across the range ie MRK, LPE, Jag, M7100 etc.
Just for interests sake, I connected two laptops together with a null modem cable and ran a terminal program on one, and programmer on the other, just to see if I could capture anything readable... at 9600_8N1, all I could see was the same string of 5 symbols (probably a 'radio, are you awake?' query).
I've got a 'sacrificial' MRK that I can & would like to experiment on, but don't know how to get it into HDT mode. How is that done for the MRK?
Old 08-03-2009, 12:56 AM
OK I have found a few more things:
About the MRK - it needs the MxTxxx99.bin test load (or as appropriate for the model MRK), connect the cable *after* switch on, and use 19200 8n1 on the terminal session as normal.
Doesn't look like the MRK understands many - if any! - cmd's.
But taking a peek inside the LPE flash load, I can see that it will understand:
cmd 1
cmd 2
cmd 3 0
cmd 3 1
cmd 3 2
cmd 4 0
cmd 4 1
cmd 5 0
cmd 5 1
cmd 6
cmd 6 5
cmd 9 0
cmd 9 1
cmd 18 0
cmd 18 1
cmd 19
cmd 20 1
cmd 21 1
cmd 27
cmd 28
cmd 32 0
cmd 32 1
cmd 36
cmd 38 0
cmd 38 1
cmd 41 0
cmd 41 1
cmd 51 0
cmd 51 1
cmd 52 0
cmd 52 1
cmd 53 1
cmd 53 2
cmd 54 0
cmd 54 1
cmd 73 0
cmd 73 1
cmd 73 2
cmd 74 0
cmd 74 1
cmd 75 0
cmd 75 1
cmd 82
cmd 85 0
cmd 85 1
Doing the same thing for a Jag700p flash load, I can see cmds:
cmd 0
cmd 2
cmd 3 0
cmd 3 1
cmd 3 2
cmd 3 0 1
cmd 3 1 1
cmd 3 2 1
cmd 3 3 1
cmd 4 0
cmd 4 1
cmd 5 0
cmd 5 1
cmd 6
cmd 6 5
cmd 9 0
cmd 9 1
cmd 18 0
cmd 18 1
cmd 19
cmd 20 1
cmd 21 1
cmd 27
cmd 28
cmd 32 0
cmd 32 1
cmd 36
cmd 38 0
cmd 38 1
cmd 41 0
cmd 41 1
cmd 51 0
cmd 51 1
cmd 52 0
cmd 52 1
cmd 53 1
cmd 53 2
cmd 54 0
cmd 54 1
cmd 58
cmd 73 0
cmd 73 1
cmd 73 2
cmd 74 0
cmd 74 1
cmd 75 0
cmd 75 1
cmd 76 1
cmd 76 2
cmd 82
cmd 85 0
cmd 85 1
cmd 87 4800
cmd 87 9600
cmd 91 1
cmd 91 2
cmd 91 3
cmd 91 4
cmd 91 5
cmd 91 6
cmd 91 7
I've got absolutely no idea what they'll all do...!
Similar Threads
HDT debugger: Info wanted. ElroyJetson Harris / MA/COM / GE / Ericsson Forum 12 06-23-2009 08:27 AM
HDT on Jaguar TXEMT Harris / MA/COM / GE / Ericsson Forum 20 11-20-2008 04:48 AM
